Question about Canon imageRUNNER C5180 Color Copier
Stuck at please wait
When i want to set up my pirnter configeration it is stuck at pleas wait....
  • Canon Expert
  • 393 Answers
Hopefully is just the hard drive failed, unplug it and retry. (turn off power first) -Carl
Posted on Apr 21, 2014
MY OKI pirnter is stuck on Loading.
The machine is failing to initialise. If you can get it into download mode then its possible to flash the eeprom with the latest version from OKI's site
Jan 03, 2016 | OKI Office Equipment & Supplies
My radio say pleas wait and one line is comig on the radio
Okay, I had the same problem. Turn off the radio, wait a couple of minutes, it needs to re-set and then make sure you're entering in the correct code. Once you enter the correct code don't forget to press enter. Good luck!
Jan 07, 2014 | 1999 Mercedes-Benz E-Class
How can reset my motherboard pasward
open the tower and remove the CMOS batery from the motherboard and wait for 5 mins, if this doesn't work change the jumper settings of motherboard(change the pin configeration on motherboard) and it would be done, it won't ask for password
Aug 11, 2011 | Intel DG31PR Motherboard
Printer getting stuck after the paper is half way through
Hi
The printer driver is corrupted, either you set up again the printer once more by adding new printer with the same name and set is as default pirnter.
Or uninstall and reinstall and printer driver and set it up again to correct the corrupted driver.
Regards
Mar 21, 2011 | Samsung ML 1610 Laser Printer
Please I'm finding problem to print from PC, i can only do photo copies why?
Hi
If you cannot print with your computer either the printer driver is corrupted or spooler service had stopped. The fastest solution is to add new printer with the same name and set it as default printer. If print the test page, then it solves your problem. Just delete the olde pirnter icon.
Feb 11, 2011 | HP PSC 1410v All-in-One Printer
Conect to network
you have to setup in printer menu option
network settings
-> TCP/IP settings
-> IP address
-> subnet mask
-> Gateway address
and ping the ip of pirnter form pc and install the driver .
Jan 28, 2010 | Office Equipment & Supplies
Pleas help me i cant fix thise proplem
Press
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for the machine to initialize.
Nov 25, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
I need to know cylinder configeration, and the two distributors spark plug wire configeration,what plug wire to set timing light on each distributor and which distributor to set first. Hope you can...
hello,your firing order 1-5-4-8-6-3-7-2,,,standing in front,left side of your engine is your cylinder 1 to 4,remove your valve cover then rotate your crankshaft,using 27mm socket,observe the movement of camshaft,and look for the timing mark in crankshaft,(ot) then you can install your high tension wire,begin on cylinder number 1,ty
May 02, 2009 | 1990 Mercedes-Benz Mercedes Benz Sl Class
My newly purchased X5340 shows a paper jam when there isn't one.
make sure you have taken all of the packing tapes off, and the paper tray is inserted correctly.
tunr off the pirnter and disconnected it from the computer. wait 5 min. turn on the printer and connect it to the computer.
Dec 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Configerations
Model? Most Hubs are not configurable, but this may not be the case with this one.
Nov 24, 2007 | Dynamode (HT809STP) Networking Hub
Canon imageRUNNER C5180 Color Copier Logo
69 people viewed this question
old marine
old marine
