Question about Refrigerators
Fridge not working on gas at night
Our Dometic 3-way fridge freezer has begun playing up in our motorhome. In the evening/night when on gas, the gas fails to ignite. We hear it clicking for a while and then give up. After trying a couple more times it starts beeping. Not a problem during the day when it works fine. Is it something to do with the temperature? The thing is that it's not that cold at the moment and we have been in far colder conditions (e.g.snow). Any help is appreciated!
    Habit-Forming:
  • 76 Answers
You may need to put a heating blanket on the LP tank, the temperature determines the amount of pressure on the tank and when the temp drops you lose propane pressure thus no ignition and a lockout alarm.
Posted on Apr 25, 2014
  • 159 Answers
SOURCE: After defrosting the freezer the whole fridge doesn't work (is warm!)
sounds like the compressor is locked up or the relay on the compressor is bad. whats happening is its drawing too much current and cutting out from the overlaod relay. that may be a bad compressor or the start relay. both the overload and the relay are under the black box on the front of the compressor. you will need to check the relay to make sure its good, and also the compressor. there should be a wiring diagram on the back that will tell you how many ohms from terminal to terminal on the compressor. hope it helped if its a newer unit the relays are electronic and if you shake it and hear like little sand pebbles in it most likley its bad and thats why it wont run.
Posted on Aug 10, 2007
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
eagle338
  • 4889 Answers
SOURCE: zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Posted on Jun 13, 2008
Dometic & Norcold RV Fridge specialist
    Verified Fixya Pro
    SOURCE: Dometic RM2350 Fridge not cold enough
    I am going to first sugest to do a direct test on the cooling unit. You will first need to locate the 110Volt heating element on the rear of the refrigerator. It is located in the tin stack on the right hand side. After locating these two wires, you must plug them in to a 110 Volt source. You can do so by cutting an old extension cord and splicing the wires to to the heating element wires, then plug the extension cord in. This will by pass the thermostat and run your cooling system wide open. If your refrigerator works in a direct test then the problem is your thermostat. If you need any more info, please feel free to contact my company Arctic Cold Refrigeration @ 1888-782-6665 or by email matt@arcticold.com
    Posted on Aug 27, 2008
    mgprice
    • 744 Answers
    SOURCE: warm fridge cold freezer
    Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
    Posted on Aug 24, 2009
    Rm4400 freezer working fridge not
    move temp sensor that's mounted in coils down or let hang if same replace sensor
    Jan 19, 2014 | Dometic Refrigerators
    I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
    G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
    Thanks
    Jan 23, 2011 | Dometic Refrigerators
    We have a 3 way Dometic fridge in our caravan. Have lived in the van for last 12 months ( grey nomads) have had no probs until trip home this week from Yulara to Victoria. Pulled up at night and freezer...
    Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
    Nov 12, 2009 | Dometic RM2652 Refrigerator
    I have a Dometic fridg in my 2005 motorhome and when I start my f
    You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
    Hope this helps,
    Jeff
    Jul 05, 2009 | Dometic RM2652 Refrigerator
    Dometic RM2607
    It sounds like the thermocouple is either faulty or incorrectly installed. In other words the sensor bulb may be very slightly to far away from the flame to get sufficient temperature to keep the gas flowing. This is a safety device to cut off gas supply should the flame blow out. But if you are parked at a bit of an angle, the flame will also angle away from the sensor, causing it to shut off gas supply. With regards the freezer being temperamental, this is a strange one, because on this model of fridge/freezer, the actual cooling starts from the freezer coil and ends in the fridge. Try to check the thermocouple first. Also be sure there is nothing obstructing the flame.
    Apr 15, 2009 | Refrigerators
    Dometic Americana Freezer/Fridge not cooling
    The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
    Jan 11, 2009 | Dometic RM2852 Refrigerator
    Refrigerators Logo
    107 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
