Question about GPS
How to install firmware - GPS
Hp 4345 49. 4c18
99% of 49 errors are caused by outdated firmware, which is the operating system of the printer. Go to http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=415205&lang=en&cc=ca and download the current firmware. Select Windows 7 32bit as the firmware files there will install from any operating system. Also ensure that you have a 4345 and not an M4345, as they are different machines and use different firmware. Follow the instructions to install on your printer. I recommend the Easy Firmware Updates as it works all the time whereas using the RFU method can often result in a time out error, if your existing firmware is too old. Be patient, if your existing firmware is too old, it can take a long time to install. The only other catch is if you have a print job stuck in your printer queue on your PC you will need to clear that first so you can install the firmware as the printer must be at a ready state for the upgrade to work.
Oct 01, 2016 | HP Office Equipment & Supplies
Tip
Trouble Shoot and Bullitens
SC120 Displayed instead of SC122 when the scanner home position was initialized 001b BICU engine firmware Install new BICU engine firmware
SC142 Intermittent or continuous 025 Defective CCD (vapour from adhesive) Replace the lens block assembly with one that is not defective.
SC280 In color mode (2C or more) with LT LEF and duplex, SC280 occurs falsely if 5 or more originals are scanned during machine warm-up. 001b BICU engine firmware Install new BICU engine firmware (ver. 1.242.01 or later)
SC280 False detection when the main motor direction changes from backwards to forwards 001i BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.31:01 or later)
SC305 008e Toner drops from the dev. unit, between the charge corona cleaner slider and cleaner driving screw
Clean the screw and slider with a damp cloth.
SC410 Unnecessary SC410 generation 001d BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.262:01 or later)
SC420 Unnecessary SC420 generation 001e BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.275:01 or later)
SC481 022 Torn image transfer belt Install a new PCU.
on Aug 14, 2010 | Ricoh Aficio 1232C Color Copier
I need LG KF900 PRADA firmware because phone having software problem please guide me how to get firmware and how to reinstall it.
Hi! Try to find the necessary firmware for your phone on LG official website. Information related to how to install firmware is here How to Install Firmware for your Hardware Mobiles Game systems
Mar 17, 2014 | LG Prada KF900 Cell Phone
How to install firmware on mygica
Usually the firmware is installed by your provider. You cannot physically install TV Box firmware because it is a product of the company that manufactured the device. The box must be taken to your service provider for you to update or flash the Bios.
Dec 12, 2013 | Computers & Internet
How do i download missing firmware for ubuntu
Loading Missing Firmware As described in the section called "Devices Requiring Firmware", some devices require firmware to be loaded. In most cases the device will not work at all if the firmware is not available; sometimes basic functionality is not impaired if it is missing and the firmware is only needed to enable additional features.
If a device driver requests firmware that is not available, debian-installer will display a dialog offering to load the missing firmware. If this option is selected, debian-installer will scan available devices for either loose firmware files or packages containing firmware. If found, the firmware will be copied to the correct location (/lib/firmware) and the driver module will be reloaded.
note.png Which devices are scanned and which file systems are supported depends on the architecture, the installation method and the stage of the installation. Especially during the early stages of the installation, loading the firmware is most likely to succeed from a FAT-formatted floppy disk or USB stick.
Note that it is possible to skip loading the firmware if you know the device will also function without it, or if the device is not needed during the installation.
warning.png Support for loading firmware is still relatively basic and is likely to be improved in future releases of the installer. Currently debian-installer will for example not display any warning if you choose to load missing firmware, but the requested firmware is not found. Please report any issues you encounter by filing an installation report (see the section called "Submitting Installation Reports").
Preparing a medium Although in some cases the firmware can also be loaded from a partition on a hard disk, the most common method to load firmware will be from some removable medium such as a floppy disk or a USB stick. The firmware files or packages must be placed in either the root directory or a directory named /firmware of the file system on the medium. The recommended file system to use is FAT as that is most certain to be supported during the early stages of the installation.
Tarballs containing current packages for the most common firmware are available from:
Just download the tarball for the correct release and unpack it to the file system on the medium.
If the firmware you need is not included in the tarball, you can also download specific firmware packages from the (non-free section of the) archive. The following overview should list most available firmware packages but is not guaranteed to be complete and may also contain non-firmware packages:
It is also possible to copy individual firmware files to the medium. Loose firmware could be obtained for example from an already installed system or from a hardware vendor.
Firmware and the Installed System Any firmware loaded during the installation will be copied automatically to the installed system. In most cases this will ensure that the device that requires the firmware will also work correctly after the system is rebooted into the installed system. However, if the installed system runs a different kernel version from the installer there is a slight chance that the firmware cannot be loaded due to version skew.
If the firmware was loaded from a firmware package, debian-installer will also install this package for the installed system and will automatically add the non-free section of the package archive in APT's sources.list. This has the advantage that the firmware should be updated automatically if a new version becomes available.
If loading the firmware was skipped during the installation, the relevant device will probably not work with the installed system until the firmware (package) is installed manually.
note.png If the firmware was loaded from loose firmware files, the firmware copied to the installed system will not be automatically updated unless the corresponding firmware package (if available) is installed after the installation is completed.
hope this helps
Jul 17, 2012 | Computers & Internet
I can't hear the phone when I receive a call. Have
I had the same problem with the latest firmware (Version 250). It was working perfectly earlier but this problem arose suddendly. I fixed it after many days by installing an older firmware (Version 245 in my case) and then installing the latest firmware again (Version 250).
You can install the firmware by going to:
Menu > Settings > Advanced > Firmware Update > All Firmware vers. > (select firmware version) > Install
Please make sure that you don't loose power and internet to your base station during the update. Also, your handset should be fully charged.
Hope this will help everyone who has the problem.
Apr 05, 2011 | RTX DUALphone 3088 for Skype
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
The phone rings but cannot hear either end
Apr 17, 2010 | RTX DUALphone 3088
Pic and vidos
I believe all you need to do is go to SanDisk's website, under Downloads, then download the Firmware Updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
After installation of Sansa Firmware Updater
* Please make sure your Sansa player is in MSC mode before plugging it in.
* Plug in your Sansa player and it will automatically check for updates.
Common questions about the Sansa Updater
Q: What does the Sansa Firmware Updater do?
A: The Sansa Updater is an application that checks for the latest firmware updates then downloads and installs the firmware to your Sansa device. The Sansa Updater is NOT a firmware.
Q: Why do I need to install the Sansa Firmware Updater to download "firmwares"?
A: Once you install the Sansa Updater, you don't have to worry about which firmware to download for your device. Sansa Updater downloads and installs the right firmware for your Sansa device.
Q: Do I need to install the Sansa Firmware Updater everytime there's a new firmware?
A: No, once the Sansa Firmware Updater is installed, future firmware updates are done by just plugging in your device.
Q: What does a "firmware" do?
A: Firmwares contain miscelleneous bug fixes and enhancements.
Q: Which Sansa players is the Sansa Updater compatible with?
A: The e200, c200 and m200 series
Q: Should I "Open","Run" or "Save" when i click on "Download Sansa Firmware Updater"?
A: "Open" and "Run" would automatically start installing the software,. "Save" would save it to your computer and you can run it in the future. We suggest you "Open" or "Run" the installer.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC"
Q: How to check for firmware version?:
A: On the e200 and c200, press "menu" and go to "Settings" then "Info"/ "System Info". For m200, press "menu" then "Information".
Nov 12, 2008 | SanDisk Sansa e260 MP3 Player
GPS Logo
14 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
