Question about Schwinn Meridian Adult 26-Inch 3-Wheel Bike
How to remove three piece threaded bearing cup from a schwinn maridian tricycle frame
Threaded bearing cup is seized into frame wont unscrew
  • charles beach
    charles beach Apr 21, 2014
    the threaded bearing cup is seized tight and wont move i used heat and wd-40 no lock im afraid if i force it i will strip the nut or split the frame at the threads desperate for some new ideals
    New Friend:
  • 169 Answers
Could you take a photo and show us the bearing cup?
Posted on Apr 21, 2014
Testimonial: "cant take picture crank still in it and cant be taken out unless both cups removed"
  • Charles Ma
    Charles Ma Apr 21, 2014
    I don't know what the bearing cups are as I am not familar with the bicycle. I also could not get a manual online. I think it should be a mechanical problem so I asked you to take a photo and show me the cups and the surrounding area. Then, I should be able to understand what you are saying and then give you possible solutions.
Where can i order a 26 inch rim for my schwinn meridian tricycle, since it's badly wobbling from 6 broken spokes?
I just put my Maridian together and two days later hit a small pothole on the left rear doing about 15mph so I called Schwinn and they replaced the wheel with no hassle. They have mnfg standards and a lifetime warranty...
Apr 24, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Seized threaed bearing cup three piece crank
contact local bike shop for asistance
Apr 21, 2014 | Schwinn Cycling
How to get a seized threaded crank bearing cup out of the frame
Which side is the cup?
If it is gear side, don't forget that it is likely LEFT HAND THREAD so will come undone clockwise ...
Why are the rear wheels locked up on my toddlers schwinn tricycle?
I took the fenders off to give a little more space for the wheels to move. Don't tighten the nut and washer right up against the black plastic spacer on the rim. Schwinn should be sending out locking spacers or nuts to fix the problem, but I don't see that happening.
Sep 23, 2012 | Pacific Cycle s Schwinn Roadster 12"...
NEED A 10X2 TIRE FOR SCHWINN TRICYCLE
I found a "10x2.0" tire made for a "Trikke" which is one of those three-wheeled scooter things.
Oct 18, 2011 | Schwinn 12" Roadster Tricycle
On my daughter's Schwinn Roadster Tricycle the right pedal no longer is able to be secured to the spindle. Since the pedals and spindles don't have any threading I assumed there was an internal,...
I got a new Schwinn for my son and we went out today for the first time. Within 10 minutes the right pedal came off in the street. Having the same problem. Did you ever find a solution?
May 14, 2011 | Schwinn 12" Roadster Tricycle
The crank on my bike is bent so im trying to get the pedals off of my schwinn z force bmx bike but i dont know how. was wondering if you could help?
Hi, As your BMX has 3 piece cranks. Here is how to go about it:
1. Unscrew the plastic cap on the side of the crank - driveside.
2. Take your 14 mm socket and ratchet, unscrew the bolt that holds the crank to the axle. Remove the bolt of both cranks(Left and Right). You can squeeze the handle of the ratchet and the crank together like pliers to give you more leverage.
3. Take the puller and screw it's socket inside the threaded hole of the crank. Hold the crank and turn the puller handle clockwise until the crank arm falls off from the axle by itself. Remove both crank arms.
4. Go to the left side and with the pliers firmly held with both of your hands(This is where the pictures differ, I'm taking a picture at the same time.), unscrew the lockring from the bearing cup.
5. Now again firmly with both hands, grab the bearing cup with the pliers and slowly test the resistance. You do not want to slip here since this will definitely strip the thread on that cup. Hold those pliers hard and go slowly, it should get it going within a quarter turn and then you should be able to unscrew it with your fingers. If not, keep on going and be careful. Remove the cup.
6. Remove the axle and bearing crowns from both sides.
7. Remove the right side bearing cup by unscrewing it in a clockwise fashion. The notch are not very wide, so might have to hold the pliers on the cup with one hand and the handles with the other. Be aware that this cup is often very hard to remove. Again, you can always purchase a specialised wrench just for that purpose.
8. Clean and inspect everything. What you are looking for is a clean and even line on the axle and inside the bearing cups. Any pits in that line will damage the bearings and they will eventually self destruct. Replace any parts that need replacing.
9. Regrease everything, the axle, the cups and the bearings. I use regular green axle grease with a touch of white teflon grease. Make sure that everything you've pulled out of that frame is extra clean, including the hole in the frame where it came from. The most minute piece of dirt can ruin your repack job.
10. Start by installing the right side bearing cup. Screw it in counterclockwise real tight. Insert the bearings and the axle. Insert the bearings in the left bearing cup and screw on the frame. Screw it until you feel resistance. Test to see if the axle turns freely and tug it up and down to see if there is any play. No play? Turns freely? If the answer is yes to both questions, install the lockring on the left bearing cup.
11. Reinstall the crank arms tightly. I would check them again in a few weeks to be sure. When you think it's tight enough, tighten some more. That's it, you're done.
Hope this helps and please vote if so :)
Aug 05, 2010 | Schwinn S2010WMB Z Force 20" Boy's BMX...
How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Apr 16, 2009 | Schwinn Mesa Gs Mountain Bike
Schwinn Meridian Adult 26-Inch 3-Wheel Bike Logo
103 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
