Try this,
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button"
2. While holding the Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the Button to set the clock
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
keywords (from display) Ultronic forecast week day humidity temperature trend comfort level - DOWN = toggles F/C temp - UP = toggles alarm - MODE = selects date/time display - hold down MODE to enter "set" mode for data currently displayed - use momentary MODE to choose target item - use UP/DOWN to change item
Normal screwed down. First pull out position. Second pull out position.
Setting the Time: Pull out the crown to position 3. Rotate the crown to set the exact time. Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not. If the date changed, then you will need to advance at least 2 hours before moving on to set the date. If you do not need to change the date, return the crown to position 1.
Setting the Date: DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am Pull crown to position 2. Rotate the crown clockwise to set to the correct date. Return the crown to position 1.
Setting the Alarm [12 hour] Pull the crown to position 2. Rotate the crown anti clockwise to move the alarm hand to the desired time. Return the crown to position 1. To activate the alarm, press the 8 o'clock button. You will hear 2 beeps. To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep. NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life] The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown You can specify a countdown of between 1 and 10 minutes. Press the 4 o'clock button to enter setting mode. You will hear 1 beep. Press the 4 o'clock button to move the central timing hand successively to the desired countdown time. Wait 3 seconds for the watch to automatically exit the setting mode. You can change the duration of the countdown [except in the last minute] at any time. e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown: Press the 2 o'clock button to start the countdown. You will hear 2 beeps. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing. When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone: There are 2 beeps every minute. in the last minute: 50 seconds=1 beep. 40 seconds=1 beep. 30 seconds=2 beeps. 20 seconds=2 beeps. 10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer: After countdown has finished the timer starts automatically. The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96. Press the 4 o'clock button to see the timer seconds [display lasts up to a minute]. Press the 4 o'clock button to see the timer hours. The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer: Press the 2 o'clock button to stop the timer. You will hear 1 beep. Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer: Countdown reset: Press the 2 o'clock button to stop the countdown. You will hear 1 beep. Press the 4 o'clock button to reset.
Setting the Timer: Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes. Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial. Press the 4 o'clock button to reset.
Resetting the Hands: If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation. To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second. Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12]. Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60. To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position. Return the crown to position 1.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
mcdevito75 here, I've never heard of a tide clock or adjustment or timeing for tide cahnges. The tide changes every 6 hours with 45 minutes at the end of that 6 hours rest you could say before the change of the tide. Refer to your local newspaper or fishing supply outlet for tide schedule.
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
Anniversary clock hands can be adjusted directly moving the minute hand clockwise. Do not touch hour hand as this may cause hand disalignment. Carefully move minutes hand with your finger all the way around till you reach desired time.
The instructions that came with my watch didn't work but after playing around with the buttons for a while i final came up with this: Press the mode button for 2 secs. The first display is the alarm. Press mode again and the time shows with the seconds flashing. Use the set button to change seconds, minutes, hours. Use the start/stop button to change from seconds to minutes to hours.This will then take you to change the month, date and day of the week. Mode takes you back to the start (time display). The alarm is changed in the same way.
To change from 12h clock to 24h clock keep the set button pressed (the alarm time is displayed) and press mode, the 'A' will disappear when in 24h mode
When the time is displayed press the start/stop button to show the date.
Not sure how to use the countdown timer or how to stop the alarm yet though!
Buttons are: A or Adjust (10 o’clock position), B or Time Memo (2 o’clock), C or Mode (8 o’clock), D or Receive (4 o’clock) and L or Light (6 o’clock) To manually change time, date, year, month and day, hold A until beep and city code appears; press A again until 12H/24Hflashes; press C to cycle through options as hour, minutes, year, month, and day flash; use B or D to change flashing option.
