Question about Watches
Casio g shock 5105
Hello, am failing to adjust the handset and digital time to read the same time. Please help out. They are reading different time.Secondly, am failing to replace ithe battery.
  • Curtis Brewster
    Curtis Brewster Nov 27, 2015
    Set the analog to"zero" first by holding down the Search button until it beeps.set the small dials using the Forward and Reverse buttons.They control each of the small dials separately.When they bot point straight up to 12,press the mode button.Use the Forward or Search buttons to set the hands to 12 o'clock.The press the set button.When the hands stop,hold down the Set button untill the digital section starts flashing and set the city day,date and time.When correct,press set to save and the hands will go to the time set by the digital clock.
    Top Expert:
  • Watches Master
  • 43,059 Answers
Read your instructions again.
Posted on Nov 27, 2015
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
Posted on Mar 12, 2008
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Posted on Apr 11, 2008
SOURCE: Reset time on Casio G Shock
how to set time on my g-shock watch dont have my manaual.
Posted on Nov 02, 2008
escapement
  • 2334 Answers
SOURCE: what watch battery do i need?
If you are asking for that, it means you want to replace battery yourself, and if you do, you will have to open your watch anyway. So, open it, take the battery out and memorise all the writings on the battery. This is the type of battery you need.
Do not forget to rate, please.
If I was wrong with my guess, then submit all the writings on your watch caseback and dial, please....and do not rate yet.
Posted on Feb 28, 2009
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
Cannot set the digital time
Read the instructions it came with or look for an interactive video online. That is going to be the easiest way.
Dec 26, 2013 | Bulova Watch
Half hour lag
Some watches can display dual times (two values) usually off by an integer number of hours + 30 minutes, Read the manual to set the digital display time then correct the analog display. Or just use one of the two.
Oct 15, 2013 | Casio Edifice Watches
Need to set the time on my casio g-shock g300 i set the digital but the analog time is saying a different time
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jan 08, 2011 | Casio G-Shock Street Rider G3004A Wrist...
How can I get the hands on my G-Shock watch to move when trying to set the time to be in sink with the digital part
I had a casio and the method was; press the mode button until the display says "HS", then press the 2 or 4 o'clock buttons to adjust the hands to match the digital time; then press mode button until normal operation is achieved.
My watch was a different model to yours, so if this does not work, then you can get
watches;
Accept terms
Jan 03, 2011 | Casio Muulti Band Atomic Tough Solar G...
Hello how do i change the time on my 4773/8? i bought it in South Africa but work in Russia please help.
you can get
watches;
Accept terms
Sep 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Please can you tell me how to reset the time on my g shock wr20bar. The clock went forward one hour ant I can't adjust it
watches;
Accept terms
Look for the instruction about daylight saving time (DST).
Aug 17, 2010 | Watches
I do not have the owners manual. How do I adjust the analog hands on the watch to correspond with the digital time displayed? Currently the the digital time and analog time are about 13 minutes...
You can get instructions from the Casio web site.
watches;
Accept terms
Aug 05, 2010 | Casio Watches
How do I adjust the day of the week on my Seiko
Hello Bob, Mike D75 here, The day of the week can be changed by pulling out the stem to set, every second time to 12"Oclock--2 O'Clock will cause the day to change.
May 28, 2010 | Watches
Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Mar 30, 2010 | Watches
Watches Logo
60 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
