Question about Citizen Eco-Drive BL006056H Wrist Watch
I have a Citizen G900 the power drain. I put it under a lamp and now the sec hand works. I also performed a complete reset and now my calendar hand continues to move and the am/pm indicator doesn't move at all...... HELP
SOURCE: the second hand is not moving
I have the same problem with my watch. The second hand
tends to stop even if it's not dim. Leave the watch outside
in bright sun for several hours. I've found that this will charge the watch so that afterwards,
the second hand will work even inside (well, not all the time,
but if it's fairly bright).
Posted on Jul 03, 2008
  • 67 Answers
SOURCE: hands don't move - digital stuff works
the hands could be silghtly bent or to tight for them to move if not change the battery
Posted on Jun 02, 2009
SOURCE: My Citizen Eco-Drive second hand is broken
I think Its required Recharging capacitor
Put your watch under lamp light for 12 hours I hope that will solve the issue if not then capacitor need to be replace or watch need cleaning
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Oct 01, 2009
escapement
  • 2334 Answers
SOURCE: Citizen Eco-Drive Blue Angel Watch C650.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all citizen watch manuals. Rate me, please.
Posted on Mar 03, 2010
freetek
  • 5568 Answers
SOURCE: hands won't sync up
It sounds like the time zone may be incorrect; check your manual to see if this can be the case. Also, these devices may wait until some time between midnight and 3 AM to synchronize with the 'atomic' standard. Make sure you have the watch near a window as this may aid reception depending on where you live.
Posted on Mar 14, 2010
I am having a citizen eco drive watch Once i put it under a fluorescent lamp for charging After couple of hours when i checked the watch was struck with second hand at 15 second. It is no working
I have one as well. Sent it back to Citizen and they told me it just needed charging.
I find it only charges in direct daylight and it takes up to 12 hours to start to recover and then another day to work properly.
I shall never buy another one!
Mar 12, 2017 | Citizen Watches
The stem on my citizen watch is turning but not changing the time or date any ideas what is wrong ?
put your finger nail under the crown and pull it out a bit ,then turn it to adjust the hands . when finished push it back in
Apr 15, 2015 | Citizen Watches Citizen Eco-Drive...
The watch is off....nothing on any of the screens and the hands are not working..so its dead! how do i get it to turn back on?
I am guessing the battery went dead. Put the watch under a lamp about 10 inches from the bulb and leave it for 12 to 24 hours. This will recharge the cell. Then you will have to go through the setting procedure from the start. Either refer to the CD, your owners manuel or the Citizen website. You will need to do the "reset" procedure most likely. This ordinarily is not needed but in your case most likely will be needed as a result of your battery going completely dead.
Mar 19, 2011 | Citizen Blue Angels Skyhawk Flight Watch...
Wath stopped
Eco-Drive powered watches can be finicky. They need a LOT of sun to initially charge the power cell, and then some strong light each day to maintain them charged. Put the watch in the window for a few days to see if it comes to life, if it does not the power cell may need replacement. Some of the earlier Eco-Drives used a capacitor that does not like to be run down from not being exposed to enough light, and will fail sooner than the newer power cells.
Jun 16, 2010 | Citizen Eco Drive Perpetual Calendar...
Citizen Eco-Drive Blue Angel Watch C650. I can't get the analog to match the digital. i have reset everything to the O positon. Reset time, calendar.
Mar 02, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I own a Citizen Eco Drive Calibre 8700 Blue dial Romen letters. I have not used it for very long time (6 months). Now when exposed to light only the second hand works but the minute hand and hour hand do...
If your watch was not stored where it could have light shining on it the LI battery would drain completely. There is a possible solution although it does not work all the time. It depends on how badly the battery has been allowed to drain.
Setup a lamp that will shine on a counter 24 hours a day and set your watch there. It helps if the lamp is about 1.5 - 2 feet above the watch. A 60 watt incand. lamp will work fine.
Leave your watch under this lamp for 3 - 4 days 24 hours a day. This will supply the solar cells with enough energy to recharge the battery and get it working again. If after this time it is still not working then the battery is just not going to accept a charge again or there is something else wrong that a watchmaker is going to have to fix for you.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
hope this help
from
Chicago, IL 60601
Ph: 312 641 7000
Oct 01, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Eco Drive Titanium
Put watch in direct sunlight, in a window for 8 hours. If battery indicator shows the watch is fully charged then you may need to look at what mode your watch is in.
Nov 09, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watch
You should be able to pull the crown out 1/2 way and turn the crown clock-wise and you should hear a click and the calender should move one day. Don't change when the hands when the time is between 10 and 2 , just manually move the hands past that time , and re-set afterwards. If that dosn't work let me know ,.There are other types of those watches , but the way I told you is the most common.
Jul 07, 2008 | Citizen Eco Drive Perpetual Calendar Watch...
Citizen Eco-Drive BL006056H Wrist Watch Logo
712 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
