Question about Cooktops
Electrolux Induction Cooktop error code E99
Unused for two weeks, and house rather cold. Power switched of and back on, **** error code E99 persists
  • Official Brand Answer
  • 4,342 Answers
Hello Cecilia, thank you for your post!
If you are receiving an error code E99 on your Electrolux Induction Cook-top, it typically relates to a communication failure. If switching your breaker off and on did not resolve your issue, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Best regards, Z.
Posted on Apr 28, 2014
Testimonial: "Yes communication problem sounds probable. I called the Electrolux service center, they had never heard of error e99, but a man came over. When he came the stove worked just fine, and there was nothing he could do, though up till two hours earlier it had refused to work for several days. It still works just fine, and as long as it does I'am happy."
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Electrolux Induction Cooktop E36IC75FSS Error Code 41
    Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
    Posted on Aug 29, 2012
    Hi , our cooktop started to show E99 code. What E99 means ? It occasionally starts to work again - but after day or two E99 appears again. Power off / on helped only few times
    Hello Cecilia, thank you for your inquiry! If you are receiving an error code E99 on your Electrolux Induction Cook-top, it typically relates to a communication failure. If switching your breaker off and on did not resolve your issue, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you. Thanks, JK
    Oct 16, 2015 | Electrolux Cooktops
    Displays error 40. Why won't it turn on?
    Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
    Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
    Prestige induction cooktop showing error E4
    Good Afternoon friend, I appreciate your inquiry!
    Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
    If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
    Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
    I am having error codes 35 and 75 come up on my induction cooktop
    Thank you for your post, friend!
    I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
    Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
    Electrolux E 95 code
    Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
    Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
    My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
    You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
    Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
    Aug 27, 2012 | Electrolux 37 in. Designer Series...
    ELECTROLUX ERROR CODE E95
    Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
    Aug 07, 2012 | Electrolux 30" Electric Hybrid...
    Whirlpool induction ceramic cooktop error E6
    my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
    Dec 15, 2009 | Cooktops
    Cooktops Logo
    688 people viewed this question
    Top Cooktops Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Cooktop Expert? Answer questions, earn points and help others
