Pioneer plasma pdp 504PG
RED LED 3 TIME BLINK
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Apr 21, 2014
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Posted on Mar 30, 2009
tvservice306
  • 458 Answers
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Posted on Nov 18, 2009
SOURCE: how do you enable the pioneer plasma hdmi settings
Hi BarryHird
on your remote press/ home menue/option/HDMI input/setting,enable that should do it..
Posted on Jan 18, 2010
orionsecurit
SOURCE: My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Posted on Jul 08, 2010
SOURCE: The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Posted on Jul 19, 2010
CHH012CD-13B
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
What is the tv code for the 40 inch dynex tv?
The code 135 should work. If not, try the code search function:
  1. Turn on the device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button)
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Aug 03, 2011 | Innovage Jumbo Remote Control
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
program shuts off. (Note LED will blink once each time you press ON/OFF button)
Mar 27, 2011 | Innovage Jumbo Remote Control
Kdf-50a11e blink 3 time on red no images no sond when i start it the green lead blink many time then the red led blink 3 time and puse then 3 time
Three flashes indicates either the lamp is not seated correctly or the lamp door is not on properly. I bet its the later of the 2 as THE most common issue is the lamp door has warped because of excess heat building up in the lamp cage. If this is the case follow the link I am providing as you are in luck as Sony is paying for those repairs. Please take a moment to rate my answer...Thanks
http://esupport.sony.com/US/perl/news-item.pl?&news_id=261&mdl=KDF50WE655
May 18, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I need the codes for the jumbo innovage control for an advent tv.
I don't see Advent TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 11, 2009 | Innovage Jumbo Remote Control
I need the codes to install on a new tv
To search for the control codes that will work on your new TV, follow these steps:
  1. Turn on your TV.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 07, 2009 | Innovage Jumbo Remote Control
I need codes
Codes for direct TV are 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217, CODE INPUT SETTING:
specific device.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn off I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 31, 2009 | RCA DIRECTV Satellite Remote Control
I need codes
specific device.
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn of I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 26, 2009 | RCA DIRECTV Satellite Remote Control
CODE FOR A JUMBO REMOTE
Use the process called code search setting it takes a bit of extra time but some codes will work for  equipment that is not listed in the manual. If for some reason this don't work the remote you purchased will not work with that brand but this is very unlikely I believe. That process is  1. Turn on device that you want to set. 2. Aim the remote at device and press and hold down the code search button for at least 3 seconds until the red led lights up solid red. 3. Press the device button for the item you wish to program E.G. tv, dvd, vcr ect. and the led will blink once and then remain solid red. 4. press on/off button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note led will blink once each time you press on/off button) 5. Once this occurs, press enter button to store the code and the led light will shut off.
Nov 10, 2008 | Televison & Video
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
