Question about Sewing Machines
Pinnock sewing machine
Need instructions on how to fikll a bobbin with cotton for a pinnock sewing machine model no lt72
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
talk2ginny
  • 34 Answers
SOURCE: need a sewing manual
I did a search and found a site that sell the manual you are looking for. I'm including a link: http://www.sewusa.com/Sewing_Machine_Manua/kenmore_Sewing_Machines_117_120_Models.htm.
I found it on Google buy searching for Kenmore sewing machine manuals.
Hope this helps. Ginny
Posted on Jan 31, 2009
JeremySew
  • 65 Answers
SOURCE: Replacement Sewing Machine Bobbin Case
Hi Jo,
Is there a way for you to email me a digital picture of your old bobbin case? I guarantee you we have one for your machine I just need to know what yours looks like!
- Jeremy
http://sewingpartsonline.com
Posted on Feb 13, 2009
  • 47 Answers
SOURCE: How to Thread the bobbin on my sewing machine
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
Posted on Jul 24, 2009
  • 3 Answers
SOURCE: Pinnock
I also have a pinnock sewmaster, here is a link to the instruction manual, hope this helps http://www.sewon.info/downloads8888/PINNOCK-FRIDOR-SEWMASTER.pdf
Regards
Posted on Aug 31, 2009
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
Jan 12, 2016 | Elna Sewing Machines
Winding bobbin on Pinnock Craftmatic MK11
How to wind and install the bobbin, and thread the sewing ...
? 8:42
www.youtube.com/watch?v=eaEjvpwXrYA
Feb 19, 2010 - Uploaded by lanido13 This is part #1 of the tutorial. It shows how to wind the bobbin. Please check out part #2 of this tutorial for ...
Pinnock sewing machine instructions 'Sewing Machines
www.offou.com/pinnock-sewing-machine-instructions-sewing-machines...
I have picked up a Pinnock Majestic Craftmatic MK11 Model HZ-140 and I am ...Machine - Setting the Needle and Awl - Threading the Machine & Bobbin.
Oct 03, 2015 | Sewing Machines
Where do you put in the oil on a Pinnock model 450 sewing machine?
Someone was kind enough to attach the user manual to their blog. Otherwise, it would be difficult to find:
http://tailororfailure.blogspot.com/2013/04/pinnock-sewing-machine-user-manual.html
Nov 08, 2014 | Sewing Machines
Pinnock sewing machine manual
I check for one & couldn't find one, so I'll send you too
these sites,, so you can email & ask them about a manual
http://www.a1sewingmachine.com/
http://sewvacdoctor.com/
Sep 09, 2012 | Sewing Machines
I have a pinnock jewel mark 3, when i sew the bobbin cotton bunches I've pulled out the bobbin re threaded it and its counting, just wondering anyone could help. cheers Marissa
have you tried a new needle
try adjusting the top tension
clean under the needle plate & in the bobbin area for lint or loose threads
Apr 14, 2012 | Sewing Machines
Bobbin tread is loose when sewing on cotton material Have adjusted tension, it is on 9. It is fine when I sew denim, which I sew a lot but I am trying to sew cotton now. I have cleanned machine, changed...
Have you checked not only the top tension but also the bottom (bobbin) tension? Top tension is usually a lever wheel etc on the machine (depending on model). To tighten the bobbin tension you need to tighten the small screw on your bobbin casing.
I don't suppose it could be as simple as this?
Jul 07, 2010 | Kenmore Sewing Machines
I am loading bobbin and can't thread cotton
Open the manual and lay it right next to the machine.
Raise the presser foot and thread the machine - always have the presser foot up for this proceedure - according to the written instructions. Same for the bobbin.
The tension should be set according to the recommendations in the manual.
Once you get the machine set-up and sewing.
Refer back to the manual as you read and test each and every feature of the machine.
This will help you become better acquainted with this particular model.
It matters not how new you are to sewing or if you started sewing when Eve needed to switch from fig leaves to textiles - everyone needs to read and apply the instructions provided in the manual. Graphics and pictures are helpful but sometimes miss important steps.
Best wishes for many successful projects.
Mar 14, 2010 | Bernina Sewing Machines
Needle won,t pick up bobbin cotton
You may need to retime the machine, email me and I will attach instructions drivewithken@blueyonder.co.uk
Mar 08, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Pinnock
Regards
Dec 07, 2008 | Euro-Pro 1260DX Mechanical Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
