Question about GSW Gaens Stahlwaren Gsw 877114 Biostar Pressure Cooker 6 Litre
Closing the cooker tightly
How can I close the pressure cooker
Does the manual for 99700 cooker work for model99665
Cooks Essentials re-brands pressure cookers from several different manufacturers. You should use the manual of the most closely-looking pressure cooker to the one you have. Here are all of the Cooks Essentials Manuals - take a look at the pictures - use the one that most closely resembles your pressure cooker:
http://www.hippressurecooking.com/category/manuals/cooks-essentials/
Mar 05, 2016 | Cook's Essentials CooksEssentials 6 qt....
Cooks essential #99770 2 art Pressure cooker lid when manual closed is not exactly even
The valves on the lid are "floating" valves, that means they will not sit firmly on the lid. However, food and gunk can get stuck in these valves. Remove it, soak it in hot soapy water, clean the inside with a toothpick and also clean the pipe on the lid that holds the weight. Your pressure cooker should be as good as new!
Sep 20, 2015 | Home
Driver door on my 1997 Lin Towncar will not close tight un less a windown is cracked open ( any window). What is my problem?
The latch striker may be adjusted just a bit too tight. What is happening is that when you attempt to close the door, the air pressure inside the vehicle resists the door closing. That is why opening a window solves the problem. There is no back pressure to fight the door closing. If the latch is adjusted properly, then you just need to put more oomph into closing the door.
Mar 02, 2015 | Cars & Trucks
How do I use the Hamilton Beach Slow Cooker 33956
From the Hamilton Beach website:Q Should I close the clips on my Stay or Go slow cooker during cooking?A We recommend closing the clips only during transport and storage. Closing the clips during cooking will not allow for proper ventilation of steam.
Jul 03, 2012 | Hamilton Beach 33956 5-Quart Slow Cooker
When installing steam release valve on 7 qt pressure cooker it is not tight but very loose
Thats the way it is supposed to be. if it was too tight, it would not automatically release when necessary.
Feb 08, 2011 | Wolfgang Puck Electric Pressure Cooker...
Do you lock the lid while cooking?
make sure u DO NOT lock the clips while cooking, its not a pressure cooker. if you lock the lid the heat and pressure from whatever you are cooking causes an air-tight seal and the lid will shatter or the ceramic pot it self will crack...
Nov 29, 2010 | Hamilton Beach Set & Forget Stay or Go...
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
How do i use the pressure cooker? After adding water and beans, I let it come to boil and the steam noise is steady....then I turn down the heat? At the end I let out the steam manually, turn off and open...
Add the water and beans. Put the lid on the cooker and tighten down. Turn on the heat and let the steam make a full plume before closing the valve. Lower the temperature to medium. Watch the gauge and when it reaches the correct pressure keep adjusting the heat to maintain the pressure for however many minutes the beans need to cook. When the time is up turn off the heat and let the cooker cool for a while. Ten minutes or so. Then slowly open the pressure valve when the pressure has reduced to a low level. If the pressure is still to high when you open the valve the water will be pulled out of the beans and the jars will only be half full of liquid. Once the pressure is down to zero, open the lid carefully because the jars are still hot and break easily. As the jars cool you will hear them pop. This means that they are sealed. Good luck.
Jun 15, 2009 | Kitchen Appliances - Others
E01 Error
The rice cooker lid has to be closed and the dial knob has to be in the lock position (turing on the pressure lamp) before cooking can start. There are two tiny wires sending signal to the main controller to indicate that the cooker is in lock position. The wires are vey tiny and they can break over the years as a result of opening and closing the lid many times. When these wires are broken, the main controller cannot detect the lock position and will give E01 Error.
Feb 02, 2009 | Panasonic SR-PRA18N 10-Cup Rice Cooker
GSW Gaens Stahlwaren Gsw 877114 Biostar Pressure Cooker 6 Litre Logo
35 people viewed this question
Top GSW Gaens Stahlwaren Home Experts
Donni Steen
Tom Chichester
Are you a GSW Gaens Stahlwaren Home Expert? Answer questions, earn points and help others
