Question about GE 30 in.JP950 Electric Cooktop
No heat cookop gives me code rf f156 , lf f116, rr f 146, lr f126
  • 109 Answers
You will need a serviceman for this one as it is a serious problem.
note: rr is right rear, lf is left front and so on.
Usually this indicates a problem with the elements or worse - electronics (if it's the electronic version).
Posted on Jun 19, 2009
Cooktop gives EEEE error code how
search this problem on Google with MAKE,MODEL and error code EEEE
Sep 12, 2015 | Cooktops
Tip
How to fix GE cooktop error code F116
First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below:
ApplianceZone.com Items
1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
Sub-Total: $170.67
Shipping: $6.95 Standard Shipping (6.95) USD
ApplianceZone.com Total: $177.62
Once i received then new burner i just replaced it and all is working fine, no error code!
First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
on Nov 16, 2013 | GE 30 in.JP950 Electric Cooktop
On my whrlpool stove the cookop on light will not go off and the stove is off
Check the door switch, its possible that this is the issue. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 29, 2014 | Whirlpool Stove/Oven/Range Cooktop black -...
No power to right rear burner or bridge, new control board and element installed already. When puower to rr burner is on an H appear on display window, like its hot yet never heated. When you know of...
Hi
The issue seems to be with the switch that is bad and should be replaced. Hope this helps...please post back with its model no for further assistance.
Daniel
Jul 07, 2011 | Thermador Cooktops
Right Front Burner shuts off after 30 seconds. Fault code f153 flashes. I have reset the circuit. Same issue occurs. Any advice?
x9009 Hello and sorry to hear about your problem.
You have a open heat sensor, one 1 of your heating elements.
I suggest you contact a service company for repairs.
I tried to help you, Please help me by vote/rate my response.
Thanks and good luck.
If you live in the Denver Co area, I can help you out
Dec 22, 2010 | GE 30 in. Profile JP939 Electric Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
STAIN ON CERAMIC COOK TOP
We have a new product that is odor less and non-toxic. $8.95 a bottle + shipping. Our web site will be up shortly: debrucepolish.com I'm Bruce, can be reached at 612-220-2236
Aug 22, 2008 | Wolf Range 18 in. SPR-100 Gas Cooktop
Fault Code
today F116 began flashing...what to do..its only 2 yrs old.
May 26, 2008 | GE 36 in. Profile JP969 Electric Cooktop
Cook top
Recommend you look up code in owner's manual. Since you did not provide make or model, there is too little to go on here...
Mar 25, 2008 | Cooktops
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
GE 30 in.JP950 Electric Cooktop Logo
659 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
