Question about Samsung MZ-7TE120BW 120 GB 2.5" Solid State Drive SATA III
Can't install windows 8 on a Samsung MZ-7TE120BW SSD drive
It starts the installation, but then tells, it's missing some drivers and doesn't continue. I tried the disk supplied with the SSD and tried downloading the latest drivers from the internet. It didn't help =(
  • Samsung Master
  • 3,320 Answers
When you are starting the new install, Windows asks for drivers, point to where the drivers are located.
Posted on Apr 22, 2014
Testimonial: "That's what I tried to do. And I used both drivers from the disk, supplied and the ones that I downloaded from the internet."
  •  Mike M
    Mike M Apr 22, 2014
    What does the BIOS say about the drive?
  • Alexei Maslakov
    Alexei Maslakov Apr 23, 2014
    I tried again today, installed the drivers from the CD that came with the SSD and everything worked okay. Don't know what was the problem. Anyway, thanks for your help!
  • 33 Answers
SOURCE: Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Posted on Oct 22, 2008
  • 17 Answers
SOURCE: My PC don't recognize HD Samsung Sata II 250gb
If you mean the drivers for your SATA harddisk, you should have gotten a CD with your motherboard that contains drivers they might be labeled as RAID, sata, or EIDE controller. when you click that it should prompt you for a floppy disk to put the drivers on, you need to put a floppy disk in drive A and then extract the RAID drivers to your floppy, when installing windows press F6 at the begining of the installation and it will act like it didn't work for a minute and then it will pop up asking you something, you press S and then you will be asked to insert your floppy disk. It might ask you if you want to install the x86 or x64 drivers, x86 is 32bit and x64 is 64 bit, if you don't know which you are using it should tell you somewhere on your windows disk. another option is to get a sata controller that isn't part of your motherboard, it would be a pci-e card and it would come with drivers. I don't know where you could download your drivers from because I think the driver you need is specific to the type of SATA controller your motherboard has in it, but I do know that seagate and western digital have sata drivers available as well for their harddrives so I don't know what to tell you. best shot is your motherboard driver CD.
Posted on Dec 18, 2008
Crankstart
  • 696 Answers
SOURCE: failure predicted on HM121HI, F1 to continue
The error you're recieving is a fair warning that the hard drive is about to die, if it were a "replace engine" light on your dash you would know what to do. Time for a new drive. If there's any dat on the old drive you need you have already comprimised it by re-installing windows, if so STOP using it and let me know your Country, state, city... from a different computer and I will point you to a data recovery specailist. If it's just a workhorse or you have it backed up, buy a new drive, re-install on it and you're back in business.
Chris
Posted on Jul 08, 2009
  • 731 Answers
SOURCE: i just installed a formatted
The drive you installed is formatted (wiped clean). It has no operating system to boot from... tthat's the NTLDR error.Power off the machine with the Win98 CD in the CD drive. Power up the machine and while the machine is POSTing (starting up showing you what's in it) watch for something saying to hit any key to boot from CD and at that point press any key . The machine should then boot from the Win98 CD and start the install
Posted on Dec 18, 2010
  • 41 Answers
SOURCE: I removed the samsung hd501lj
You need to prepare the drive for Windows. This unfortunately usually means reformatting. You should be able to tell it to reformat and prepare the drive from the disk management console if you right click on the disc.
Posted on Apr 07, 2011
My hp laptop originally had Xp pro and the.drive was erased .i try to install a factory Xp pro disk and it wont detect a hard drive , thats where my new install stops with that problem page
redux, (shorter but inputs are weak)
no computer stated,(hopeless for sure0
no disk stated only the word ?FACTORY?means what?
the Micro Soft dics is 4 different releases 2001 to 2008, sp1,sp2, and sp3 too.
the HP disc is from ,HP.com
the first MS XP disc will not see SATA drives
it lacks the driver ,.
The HP disc works because they put it there.
not some randome accident HP disc ,supports
only you unstated HP laptop
The newer MS XP disc,SP3 might work, you tell me.
why load and obsolete OS, a virus magnet .
with the wrong disc, MS
hit F6 key, and load the correct SATA driver now.
we did that for years. (but it needs a stinking floppy disk, ouch)
32a4af19-9d52-4e14-b1a3-7283f9101169.jpgxp-5lulyt1gpqn0flmkwfjfqmqj-3-2.jpghp-5lulyt1gpqn0flmkwfjfqmqj-1-3.jpg
Feb 16, 2017 | HP Computers & Internet
SATA port 0 INTEL ssd locked
Please check the solution here:
1) Find or make an XP install with SATA set to IDE mode
2) Install .NET 2.0 & Intel SSD Toolbox
3) Shut down
4) Connect up your 'bricked' Intel SSD
5) Turn on system
6) Start Intel SSD Toolbox, and the SSD should now show up
7) Start another secure erase on it, and it should go through
8) Your Intel SSD is now unlocked again
http://forum.notebookreview.com/threads/how-to-resurrect-an-intel-ssd-locked-by-the-intel-ssd-toolbox.583269
You might also want to follow this Microsoft KB - You receive Stop 0x0000007B error after you move the Windows XP system...
And for some background info - https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
Hope that helps!
Peace
Apr 20, 2015 | Acer Aspire 5610-4648 Notebook
How do I add a separate Samsung ssd 128gb drive with windows 7 on a Dell xps 8700 with windows 8.1 already on it? Is it possible?
On some computers, pressing a special key before boot up displays all the bootable devices. Using the arrow keys one can select which device to boot.
Sep 16, 2014 | Dell XPS 8700 Desktop PC - 4th Gen. Intel...
Can someone advise me how to reload a driver on an ssd which I accidentally deleted
What driver did you delete? You maybe be able to get from your windows disk if you have one or you maybe able to get from the manufactures website if it is something like your video card. If I know what you deleted will help answer.
Aug 03, 2014 | Samsung 250GB 840 Evo-Series SATA III...
Windows 7 install stops and reports that a required driver for the CD/DVD drive device is missing.
you need to load the device driver prior to starting the install as it looks as if the windows installation drivers do not support your DVD drive. Get the driver on a USB stick and load it at the first of the install.
Feb 13, 2013 | Samsung DVD Burner SATA Model SH-224BB -...
Can't eject cd from drive in samsung chronos windows 8 version
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 15, 2013 | Samsung Series 7 Chronos
Trying to start computer with SSD and HDD, NOT happening!
Have you tried going into the bios to see if the ssd is recognized and have the computer boot from the ssd So connect the drive and put your windows disk in and install to the ssd During the install it will scan for drives and ask which drive you want to install on Make sure you check the boot options in the bios to allow the connect drive
Nov 23, 2012 | Computers & Internet
Ssd won't show up as destination drive.
I'm not sure this is your problem, as you question isn't descriptive enough. But here's a solution if I do understand your question correctly.
When I have installed new hard drives in the past, I did the physical install, turned the computer on, and they just worked. Not so with SSDs I've installed. After the physical install, the SSD does not show up in the "Computer" window with all the other drives; because it's not FORMATTED.
Solution:
Navigate through:
Start > right-click on "Computer" in the right pane > select "Manage" > in the left pane select "Disk Management"
All the drives will show up in the main window, including the SSD you just installed. If it does not show up, there's a problem. Maybe one of the cables isn't fully inserted, or there's a defective cable, or a defective SSD.
You can tell the SSD from the other drives by the Gigabyte capacity, and also by the fact that it does not have an assigned drive letter (e.g. C:). Also, it's named something like "New Edition".
To continue to formatting, navigate:
Right click the SSD > select "Format" > select "Quick Format"
A drive letter will be assigned. You are given the option to change this letter if you want. Also, you are given the option to name this drive. This name will appear with the drive listing in the "Computer" window. I simply used the name "SSD", however if you want something more discriptive or colorful, it's your computer, it's your SSD, you can name whatever you want.
The other format option is for when one is installing a used HD which may have bad sectors. That option scans for bad sectors, and takes a LOT longer to format. Not necessary for a new SSD. Plus, you can scan a drive for bad sectors anytime with the "chkdsk" command.
The SSD is now ready for use, including for use as the main drive. Windows will happily load onto this drive.
Nov 10, 2012 | Samsung 830-series Mz-7pc128n/am 128gb 2.5...
HOW TO IMPROVE THE SPEED IN WIN7
The best way to speed up W7 is to install an SSD (Solid State Drive), such as one of these drives:
http://www.compusa.com/applications/category/category_tlc.asp?CatId=5298&name=Internal-Solid-State-Hard-Drives&
While they are expensive, you will_not_ regret the investment. To save $, you don't need to purchase a large SSD drive. Put W7 on a small capacity SSD (commonly referred too as a boot drive) and then use a regular hard drive (your old one) for mass storage. For example, on my computer, I use a 40GB SSD for W7 (C:) and a regular 500GB hard drive (D:) for music, videos, large downloads, pics, etc.
There are also a plethora of websites that will show you how to speed up W7. Here is one:
http://www.computingunleashed.com/speed-up-windows-7-ultimate-guide-to.html
Another way to speed up W7 is to install more memory, but you won't get near the noticeable performance increase as an SSD. In fact, after installing an SSD, if you try to enable ready boost on a flash drive W7 will tell you that it is not neccessary because you already have an SSD that is faster.
Feb 06, 2011 | Computers & Internet
Tell me what i can do to make my asus G73-JH laptop recongnize and see my new SNVP325-S2/64GB on win 7 installation. and the installation screen i want to select my ssd drive to install win 7 on it but my...
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Dec 05, 2010 | Kingston (SNVP325-S2/64GB) SATA II Solid...
Samsung MZ-7TE120BW 120 GB 2.5" Solid State Drive SATA III Logo
89 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
