How do you enable the touchpad on an Android - Computers & Internet
How do you enable the touchpad on an Android laptop?
  • Computers & ... Master
  • 3,982 Answers
You usually can turn off the touch pad function key FN + F9 or turn it on with most laptops
Posted on Apr 21, 2014
Compaq 730us touch pad not responding
Hi
To fix an unresponsive touchpad on your laptop/desktop XP Home, XPPro:
Reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 06, 2011 | HP Compaq Presario 730US Notebook
Dell inspiron mini 10 touchpad frozen and I can not log on
Hi slimmerkitty...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
If unsure which Function key enables and disables the touchpad, try each one at a time(F1,F2,F3) and then attempt to use the touchpad after each one.
Sep 05, 2011 | Computers & Internet
Touch pad scroll gestures very intermittent.works then doesnt
Hi tommymul6...
Try this solution to your problem
Sep 04, 2011 | Computers & Internet
My loptop touchpad (mouse) had a problem, it's lock i didnt know how to open it again..
Hi
Sep 04, 2011 | IBM ThinkPad T43 Notebook
How to enable touch pad
hello,
here are the steps to enable touchpad
Please, Press the "On/Off" button to turn on the touchpad. If your HP laptop does not include an "On/Off" button, press and hold the top right corner of the touchpad for five seconds and then release. A small light turns off and the touchpad icon appears briefly.
Click the Windows "Start" menu and click the "Control Panel."
Select the "Device Settings" tab and click "Enable" to enable the touchpad. Click "OK" to save the changes.
After performing the above steps touchpad will be enable.
if the issue persists, please do not hesitate to contact.
regards
Apr 24, 2011 | HP Computers & Internet
How to enable touchpad I disabled by mistake and
Step 1: Click on Start and then click on control panel.
Step 2: Hardware and Sound......Devices and Printers....Mouse.....Mouse Properties.....Device Settings.....Touchpad.......Enable........(Windows 7).
In Windows XP
Dec 18, 2010 | Dell Inspiron 1545 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
My mousepad's scroll feature is no longer working after I took my laptop to Best Buy and had them install a new harddrive under warranty
Right above the Touchpad is the On/Off button to Enable the Touchpad, or Disable the Touchpad.
If the Touchpad light is on, then the Touchpad is Enabled. (The On light is right above the Touchpad also)
Do you have the Touchpad enabled?
Dec 12, 2009 | HP Pavilion dv1000 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Touchpad inactive
is there a small button near or on the touchpad, most laptops have a small button that enables and disables the touchpad just by pressing it.
Jan 13, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
