Question about Brother LS-2125 Mechanical Sewing Machine
Joy model PF 1500 bobbin case is disassembled how do it put it back together
3 Suggested Answers
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
  • 7 Answers
SOURCE: bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Posted on Jul 31, 2009
How does the bobbin casing fit together?
It would probably be better to just purchase a new replacement bobbin casing. If the old one is disassembled, it would be very difficult to get it back together and have the tension function properly, whereas a new one will be set at the factory.
Aug 13, 2017 | Sewing Machines
How to reassemble the bobbin works
The machine is unidentified
Jul 14, 2017 | Sewing Machines
The insides of the bobbin area of the machine has came a part and the bobbin will not lock in.
We need to know the make & model of your machine before we can begin to address your problem.
They probably came disassembled because they are meant to come apart for cleaning and maintenance. Your owner's manual may have instructions how to put it back together.
Aug 05, 2016 | Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
CANT GET TENSION SET AND ITS SO FAR OFF DONT KNOW WHERE TO START....vogue stitch old..model.label on back says model 1300/1500 or mercury model 704
try www.sewusa.com repairs page for troubleshooting help. start by cleaning and oiling machine. then wind a new bobbin and put in a new needle. load bobbin into bobbin case and ensure thread goes into tension spring. now dangle bobbin case by holding thread tail, bobbin should hang in the air but release thread if you pull it. adjust the tension screw on case 1/4turns only and test again until you get it tight enough to 'dangle'. now load bobbin into rotary hook of machine and thread top. now test sew and adjust top tension in small increments if neede to balance the stitch. but if top tension is wirking okay then 4-6 range should be fine.
Aug 24, 2011 | Sewing Machines
I just got a new Singer Simple. I had a problem with the needle thread getting caught in the bobbin shuttle. I disassembled this area, found a random thread, and cleaned it out. I put it all back together...
Do you have the bobbin thread going the right way, according to owners manual some go clock wise some go counter clock wise when you pull the thread after bobbin inserted in bobbin case
Dec 27, 2010 | Singer 3116 Simple
My machine is Model #981668. My whole bobbin case
My husband put it together. It's been a while since I used it.
Thank you anyway.
Oct 07, 2009 | Necchi Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
44 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
