Question about Frigidaire Washing Machines
The Water does not stay in the washing machine! Admiral 10.1kg
  • Frigidaire Master
  • 5,323 Answers
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more. Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine. Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Posted on Mar 31, 2015
SOURCE: Admiral washer wont take in cold water
I to have the same problem except it is my hot water that dribbles
Posted on Jan 06, 2008
Yozzer6821
  • 116 Answers
SOURCE: admiral washing machine
Possible timer problem, timer reverses motor to agitate this is not hapeniing, check timer or wiring to motor.
Posted on Nov 09, 2008
SOURCE: admiral washing machine will not start
admiral washer machine will not start and before it died there was a weird noise coming from the machine.
Posted on Jul 10, 2010
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
Posted on Aug 04, 2010
caroldon
  • 17130 Answers
SOURCE: admiral washing machine keeps filling
The water level sensor is faulty. After the inlet valve is opened the program controller needs the signal fromt he water level sensor. Thi is normally a pressure switch and as the water builds up the tub through a small opening the water flows through a tube to trigger the switch. So find out the pressure switch and replace. Only once the sensor clicks will the program proceed to wash . Otherwise you can spin becasue the water level sensor need not work for spinning as the level is down.
Posted on Sep 17, 2010
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
Admiral washing machine water not hot enough during all cycles.
newer washers have a temp sensor and the washer is programed for around a 100 to 110 degrees F, depending on manufacturer, so if your washer is new it is doing what it is supposed to do, sorry.
Jan 03, 2012 | Washing Machines
Drains during wash cycle
Here is a tip that I wrote about that problem with washing machines...
Water will not stay in Washing Machine
http://www.fixya.com/support/r4696322-water_will_not_stay_in_washing_machine
Jul 17, 2010 | Admiral Washing Machines
My washer machine keeps filling but not holds the water
Here is a tip that I wrote about the problem you are having with your washing machine...
heatman101
May 07, 2010 | Admiral AW22 Top Load Washer
My washer machine does not hold the water keeps draining
heatman101
May 07, 2010 | Admiral AAV7000A
Admiral top loading washing machine overflow water
Most likely the water level sensor - check www.repairclinic.com
Jul 31, 2009 | Washing Machines
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
Admiral top load 10.1 Kg 4 speed Combo has become
water does not stay in drum goes straight out?
Jun 04, 2009 | Admiral AW22 Top Load Washer
Dec 15, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
