Question about Oster 6678 14 Speed Blender
Lights are flafhing on soup mate pro
Won't start
I have a soup maker. When turned on it shows 88 on it and won’t work. What is the problem. No instructions came in box so cannot check
Please could you provide some more information, make & model etc so that I can try to assist you, many thanks.
Mar 01, 2018 | Blenders
Magnet on lid of soup Mate lost. thus he machine will not start. Magnet is a particular size. Where can I get a replacement? I'm in Perth Western Australia
contact the manufacturer on the net
go to an appliance repair shop and see if one is available
how big is the magnet and will cutting up a fridge magnet help
what about cutting up a magnet from a fridge door seal
just ideas to consider along with magnets from tools , diff plugs
small speakers ( head phones etc)
Sep 14, 2015 | Blenders
I need an Instruction Booklet for my Soup Mate Pro Please help?
You can download a manual from this site.
http://www.ebooke-zz.com/soup-mate-pro-instruction/
Jun 08, 2015 | Blenders
How do I locate a manual for a Ginny's soup blender
Go to where you bought it and ask for help or if you know the manufacturer address phone or send a request letter.
Sep 12, 2014 | Montgomery Ward Ginnys Brand Soup Blender
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
May 19, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Soup mate pro won't start
try powering off, removing contents from the container, refill using less contents and push the contents to the bottom plate. Turn power on. If beeping stopped it will work. Another thing to try is turning the rubber gear on the base or bottom of the container slightly then put container back on the base, as before do this while power is off at the power point for safety. Regards Greg T. My mother bought one and Ive had to step in as Im the only one to make it work. Hope this helps you. I am about to go past for the 3rd time of her using this device to see if I can help do a re-heat as she made a soup and its now not playing ball again 4 her. Forced to contact the distributor of course!
Jan 09, 2014 | Oster 6678 14 Speed Blender
Soup maker keeps showing 8888
Hi Doreen, not a fault. Press the menu button for P1 to 5 which are the Programmes. If you try to work it without the magnetic lid, it won't! E2 shows. I resurrected a Cooks Prof. Without lid or sleeve and am making great soups with an improvised magnet and an old pot lid of my deceased wife's. Works fine. I can't locate Instructions but have bought Soupmaker recipes on Kindle and enjoying some great tasty soups each lunchtime. Happy to share my trial and error experience with you. Good luck,
Alex, Edinburgh
Nov 21, 2013 | Cook's Essentials Soup-a-chefs Electric...
When I select an option for my soup maker it comes up with E2. What does this mean please?
Mine is doing it as well and I don't know what it means. Does anyone else? Mine is a Cooks Professional.
Oct 26, 2013 | Cook's Essentials Soup-a-chefs Electric...
Soup maker keeps beeping
I have also had a beeping problem and it was caused by overfilling. I removed some of the liquid and it worked!
Jan 13, 2013 | Cook's Essentials Soup-a-chefs Electric...
My Cuisinart soup maker keeps switching off
How you removed the bottom? Screws are so deeb and I cant see what screwdriver I have to get.
Nov 20, 2012 | Cuisinart SSB1U Soup Maker
Oster 6678 14 Speed Blender Logo
49 people viewed this question
Top Oster Blenders Experts
Craig Butler
Craig Butler
Angel Joseph Jr.
Angel Joseph Jr.
richie46
Are you an Oster Blender Expert? Answer questions, earn points and help others
