More often than not when any dishwasher motor will not turn, it is the motor start capacitor at fault. It is quite rare for the main wash pump to seize. The start cap is a cylinder about the size of a D size battery and would have 2 to 4 wires going to it. It may look like it is melted, or maybe not. But usually will only cost you a few dollars from an appliance part store or ebay. just make sure you get the correct mF rating.
Basically, the wash motor is jambed. Gain access to it and turn the pump shaft. If jambed, it will then loosen up and function again. If it is free to turn, the capacitor has then short circuited.(replace the cap).
The loud humming noise can be due to the pump sticking if a piece of debris gets trapped in it or an intermittent fault on the pump capacitor or starter relay.
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it..
turn off the power the the dishwasher...
.remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
I was looking for spare-parts for my dish-washer Siemens Lady-Plus 25, bought in 1993 !....and I find your request.
I still have the multi-language "Operating Instructions" manual for it....
Still needing one ?
I can of course send you via e-mail, the english pages of it.
