Question about Kitchen Appliances - Others
Looking for a glass holder for maxi heat wood burner
Where do I put the wood chips in?
this depends on the type of appliance you are using A smoker or a charcoal barbecue will use chunks instead of chips so I'll assume you have some brand of gas broiler that does not have a drawer or cavity for wood chips engineered into the design of the appliance.
In this instance you can soak chip overnight and loosely wrap them in aluminum foil. Place the loosely wrapped chips over a burner on the radiant tray or briquette tray so the heat is directly on the wood chips.
Close the hood and keep the other burner off or low so the heat on the wood chips soaked overnight causes them so smoke and not char. You need the wood chips over the flames so they smoke.
Oct 18, 2014 | Grilling
Ferrari kooga 4 holder
Hi
The product you have selected does not match up with your description. If you have an issue with your Maxi Cosi Loola please let us know but we do not deal with Ferrari Kooga 4 holder.
Sep 03, 2012 | Maxi-Cosi Loola Oxygen Umbrella Stroller
The smoker heats ok but no smoke
Assuming the smoker is heating up correctly to at least 225 - 250 Degrees F and you have loaded the wood chip holder with soaked wood chips, I can't think of any reason smoke is not being produced. Unless, you soaked the wood chips to long. 30 minutes is generally all that is necessary. The chips should start smoking before you place meat, fish or chicken in the smoker.
Thanks for choosing FixYa.
Sep 15, 2011 | Masterbuilt 20070106 Electric Smoker
Hello, I'm trying to figure out how to remove the cup holder from my maxi cosi foray stroller. Any help?
hi
looking at the instuctions page6
http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/CV053%20inst_EF_052909.pdf
it looks like it slides up (maybe it has a small bump in plastic to hold it in place)
Oct 22, 2010 | Toys
Rewire the speed heat burner
Setting up the glass top I aligned the wires to the terminals by size and length of each wire.With the wire situated in their proper holders on the stovetop base it was easy to see where thet should go, looking at the other burners made it easier to see where each wire fit in the pattern.
Jan 06, 2010 | KitchenAid Kitchen Ranges
I have a napoleon wood fireplace, I just installed it in a fireplace. It seems like I can't get any heat out of it. I installed a cheminee liner up the cheminee. I think that the heatloss is going up the...
an open fireplace is not going to heat your house only 5 feet in front of the fire place. 75% of the heat goes out your chimney and burns the wood very fast. sorry to say but if you are looking for heat you installed the wrong unit!
Dec 14, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Wood burning stove with integral burner not heating the water eno
When is the last time you brushed out the burner tubes of the boiler? This is how heat transfers and if you have a coating of soot, it will prevent heat transfer. check this and post me back
Dec 01, 2008 | Water Heaters
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
