Question about Simplicity Denim Star SW210
Simplicity denim star stitch length wont change
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
  • 22 Answers
SOURCE: I am looking for the power cord for the Simplicity
Try this online dealer:
http://www.sewingmachinesplus.com
Posted on Nov 10, 2009
SOURCE: I need to set the tension on my simplicity denim star sw210 machine, how do I do that? It seems that the top stitch is good but the bottom stitch looks really loose.
try adjusting the top thread tension one number higher till it looks better
Posted on Mar 21, 2012
SOURCE: Simplicity denim star SW210 will
bottom thread is getting bogged down and stops working, I cleaned and ioled it and it still doing it.
Posted on Aug 15, 2012
SOURCE: where can I buy foot pedal for SIMPLICITY AMERICANA SERIES - DENIM STAR - Model SW210
try this link for parts
http://www.sewingpartsonline.com/simplicity-s210-sewing-machine-parts.aspx
Posted on Apr 08, 2013
How to set dial for straight stitch
The "N" on your stitch dial should point or line up with the "A" on your stitch dial. It should now make a straight stitch. Hope this helps.
Oct 05, 2015 | Simplicity Denim Star SW210
Free owers manual
your question is put under the sewing machine name of
simplicity denim star sw210, so that is the links I'm going to supply
for a manual,, but the manual is not free, I don't know where you can
get one for free
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw210.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-denim-star-sw210-download.aspx
Aug 06, 2012 | Simplicity Denim Star SW210
Zigzag stitch only stitches on the left side.
if the zigzag stitch only stitches on the left side it's very possible that the cam or gear inside that does the zigzag stitch is either worn out or broke or damaged in some way, only a repair shop service tech can tell
Aug 26, 2011 | Simplicity Denim Star SW210
Settings
Width is one.
Length depends on the thickness of the fabric; 2.5 is the normal setting, but you may have to adjust to your liking or the age and condition of the machine you are using.
Fold a scrap of the fabric you will be sewing and test the settings, then write the settings down or on the sample for future reference.
May 07, 2010 | Simplicity Denim Star SW210
Not completly threading or something
i was told this is a timing problem
Feb 26, 2010 | Simplicity Denim Star SW210
Winding the bobbin - Simplicity Denim Start SW210
you have to move the lever so as to engage it to the wheel. Don't thread the thread all the way to the needle. only lead it around the top position. Disengage the small wheel on the right so that the needle doesn't go up and down.
Jan 06, 2008 | Simplicity Denim Star SW210
Simplicity Denim Star SW210 Logo
22 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
