Question about Maytag Ensignia MAV4758AWW Top Load Washer
Dryer is wroking fine but no heat? any ideas?
  • 71 Answers
Heating element may be burned out. Try alternate settings to see if it works in other temp settings.
Posted on Jun 19, 2009
I have a maytag gas dryer. Atlantis. It is not heating up. It is blowing air just fine. I cleaned out all lint. Vaccumed the duct. I have no idea what to do.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.
Aug 06, 2011 | Dryers
Dryer seems to work (runs, tumbler turns, timer works, air flows) except there is no heat. I see that there could be several reasons for this, how do I isolate the problem and fix it?
First look for reasons why safety components would trip and remedy them thangsthemobilian_1642.jpgthemobilian_1643.jpgthemobilian_1644.jpgthemobilian_1645.jpg
So once we have that ironed out we now have an idea where to look first. If the dryer is clean and the vent is clear and you still have no heat then one of your heating components have failed. The heating components are the element, coils, sensors, ignitors and controls.
So if the element is bad simply replace it and you now have heat but what if the element is ok?
themobilian_1648.jpgthemobilian_1649.jpgthemobilian_1650.jpgthemobilian_1651.jpgthemobilian_1652.jpgthemobilian_1653.jpgIf your ignitor and flame detector is fine you may have the very common problem of weak coils themobilian_1654.jpg
If it turns out thet your safetys are fine and your heating components are fine then you could have a bad controlthemobilian_1655.jpg
If your control is fine you could have a bad circuit breaker.The motor on American machines is 120 volt of alternating current but the 5000 watt heating element requires 240 volts.themobilian_1656.jpg
I have include a dozen or so Dryer service manuals and more HERE
Let Me Know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 03, 2011 | Dryers
Lost heat for my Dryer Whirpool LER3624JQO. Discovered heating element had a break in the coil. Bought new element at local appliance store, while I was there I had all 3 T-stats tested, everything tested...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 04, 2011 | Whirlpool LER3624JQ Electric Dryer
Replaced heat element, thermostat. Dryer ran fine for 10 minutes then shut off. Breaker fine. Lights on dryer working. Any ideas?
YOU DON'T MENTION WHAT BRAND OF DRYER YOU HAVE. DEPENDING ON YOUR DRYER IT COULD BE A FAULTY MOISTURE SENSOR.
Jan 29, 2011 | Dryers
Frigidaire stackable washer and dryer...model # GLET1031CSO was drying clothes, opened dryer to check, will not come back on. Washer still wroking fine. Can you help me? I checked breaker, it is fine....
Sorry to read about your problem, I hope this helps you out.
You may have a defective door switch, or lost a control board.....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Frigidaire Washing Machines
Dryer is not wroking
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 25, 2010 | Frigidaire FEQ1442ES Electric Dryer
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Maytag Ensignia MAV4758AWW Top Load Washer Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
