FC message on the screen
How to erase a FC error on Hisense air conditioner screen
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Hisense air conditioning unit displaying FC,
FC Outdoor low pressure drop. Check your gas pressure. It should be 60 PSI in ambient temp of 98 degree Fahrenheit.
Less gas pressure not only due to gas leak. But also indoor coil and air filter chocked . Service the unit and test again. Helpful?
Posted on Jan 02, 2011
hvac1960
  • 2133 Answers
SOURCE: AIR conditioner samsung aqv12a error message "E101
ErrorCode = 101
Explanation and Checking points = Indoor unit communication error - checkwiring
Posted on Oct 27, 2011
  • 127 Answers
SOURCE: NOMA air conditioner/dehumidifier/fan model 043-5441-8
hello,
you can find the service manual here :
http://www.manualgalaxy.com
Posted on Jul 18, 2013
Where is the panal button inside due to fix fc error solution
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
If you need help with your system check out Boca Raton Air Conditioning Service
May 03, 2016 | Heating & Cooling
How to fix fc error?
My Amcor ductless unit aws181hx gives 2 messages f c and p3
FC = Compressor Fault
P-3 = Overload-Current/Voltage/Temperature
Call Amcor Tech Support........Pridiom 201-266-8234 option 2
Jul 05, 2011 | AmcorAire UCHW-H24AF2 Split System Air...
NOMA air conditioner/dehumidifier/fan model 043-5441-8 gives E4 error message and shuts down. This is a new unit and the owner's manual and Hisense USA company are useless! Help, please!
the unit is full of water, carefully lift unit into bathtub and drain all the water, both top and bottom corks removed. Usually caused by airlock in drain hose
Jun 29, 2011 | Heating & Cooling
I get FC error on the AC dispaly
i got error on my air conditioner 1.5 ton after five seconds of turning it on it disply "Fc" on LCD. who can i solve this problem.
May 26, 2011 | Whirlpool Heating & Cooling
I hav bought a split unit of hisense 2 monthsback i dont how but since 2 days even if i put off the unit with remote there is "FC"sign lit on the unit which does not go off ...the unit model no...
Hi and welcome to FixYa, I am Kelly
Your not going to hurt it by using it with the FC being displayed. FC = Filter Clean. This will appear after every 100 hours of use. Your supposed to remove the air filter and wash it. Usually you have to push the right button on the control panel (often labeled mode) and either the UP or DOWN temp arrows for 3 - 5 seconds to get your display back to normal. Pushing the Up arrow at the same time as the MODE switch should get you a Fahrenheit Display. Pushing the Mode button and the Down arrow at the same time should get you a celcius Temp display.
( I am pretty sure you have to do this on the unit and not with the remote. )
Why manufacturers DO NOT put this information in their user manuals is a bit baffling to me as a service tech. HiSense is not the only one that omits this information.
Should the steps above not resolve your FC display call your HiSense Distributor and ask them how to you reset the Filter Clean (FC) Display. They will be able to tell you over the phone.
Like I said in the beginning your not going to hurt it by using it with the FC being displayed. If you change the temp up or down by 1 deg you will see the display for a few seconds then the FC will re-appear until you reset it.
This is the AU Contact data:
Phone: 1800 HISENSE (1800 447 367)
Fax: .
Email: enquiries@hisense.com.au
Email them and ask how to reset the FC on the display. Remember you will get this display every 100 hours of operation.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Heating & Cooling
Hisense air conditioning unit displaying FC, what does this mean?
Jan 02, 2011 | Heating & Cooling
Describe FC error in dawlance 1 ton AC
Its A filter clean indication that means your filters of air conditioner is full of dust and need to be clean.
To clear the FC message, open front panel of your ac and there will be a pinhole switch "Automatic" or "Reset". Keep it pressed for 5 seconds and FC will be removed.
PS: Dont panic if a/c is turned off instantly when you press the button as its normal. Hope it helps.
Aug 22, 2010 | LG LFX25975SW (247 cu ft) Bottom Freezer...
I am getting error message FC on oven control
FC Communication error between boards Wiring harness or power relay board (PRB)
Oct 28, 2009 | Jenn-Air JES9900BAS Stainless Steel Gas...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
