Question about Makita Strimmer Electric - UM3830
Replacing stimmer line on spool - Makita Strimmer Electric - UM3830
Can i change stimmer line to brushcutter
any I have ever seen the line can be replaced .
Jul 31, 2015 | Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Replacing the cutting string
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, 11
Feb 11, 2012 | Garden
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Having trouble replacing trimmer line
Hello. I just answered a similar question not twenty minutes ago. Hope this helps.
Please read all the way through this before beginning to actually rewind the spools.
1. Pull the spool off of the head. Clear the dust and debris out.
2. Note that it is actually two spools that are separated by a disc, and that the disc has a slot in it. The outer spool is the spool closest to the bump head, and the inner spool is the one that fits closest to the machine and has notches in it. If you turn the spool so that the inner spool base is up, you will see that there are decimal numbers next to the notches. The decimal numbers are your line size(s). I say sizes here as some machines will accept more than one line size. You will also notice arrows on the inner spool base, telling you which direction to wind the line on to the spool(s).
3. Wind the inner spool first: Put the end of the line into the hole that is in the core of the inner spool. insert ~1/8". Wind in the direction of the arrows until you get roughly even with the divider between the inner and outer spools. You want to end up with your line 180 degrees from the slot in the divider, and snap the line into the notch that is in the inner spool base. You want about 6" of line beyond the notch. Cut the line, leaving a 6" tail.
4. Wind the outer spool: Wind the outer spool like you did the inner spool, filling the spool as before, and ending at the slot in the divider. Feed the line through the slot and snap it into the notch. Cut a 6" tail as before.
5. Reinsert the spool: Get the spool close to the machine. Insert the tails into the grommets in the head, and snap the head into place.
6. Preparing the line for use: Push the spool in as if you were bumping it against the ground to advance the line. Grab the tails and pull. This will release the line from the notches, and should release about 1" of line in doing so.
You should be good to go.
Every so often, it's a good idea to put some graphite dust into the spool just before putting the spool back onto the machine. This helps when you are advancing the line. I do this every 8 to 10 times I rewind the spools.
If this fails to correct your problem with the spool, it would be best to purchase a replacement spool.
Best regards, --W/D--
Jan 31, 2011 | Tanaka 22" Double Sided 24cc Hedge Trimmer
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need to know how to change the trimmer line on a weedeater RT112C
REPLACING THE LINE
1. Disconnect the unit from the power
source.
2. Remove the spool by firmly pulling on the
tap button.
3. Clean entire surface of hub and spool.
4. Replace with a pre-wound spool or cut a
length of 30 feet of 0.065′ (1.65 mm) diameter
WEED EATER brand line. Use of
heavier lines could overload and damage
unit.
Also here is the manual if you need it.
http://dl.owneriq.net/5/56bed657-13ad-4194-85f3-2c4890bcfd6d.pdf
Good luck
Sep 25, 2009 | Garden
B & D trimmer feeding too much line
Do you remember putting the spring back in when you filled it with new line. You mite check to see that it is in there.
Good luck
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
Makita Strimmer Electric - UM3830 Logo
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
