Question about Craftsman Garden
Rough idle on carburettor car - Craftsman Garden
2 Suggested Answers
  • 496 Answers
SOURCE: I have a 1990 corolla
Check for a malfunctioning EGR valve. This valve is only selected to perform when the engine is warm. It has a vacuum diaphragm which can crack and lead to vacuum leaks. This will cause rough running. The EGR valve should be vacuum checked to see if this diaphragm is leaking. This valve can also stick open due to carbon deposits. When the valve sticks open, the fuel/air mixture is leaned out and rough running ensues. This problem is practically expected on a vehicle of that age.
Posted on Mar 21, 2011
How do I fix an erratic idle problem?
Solving Automotive Idle Problems - EricTheCarGuy- Stay Dirty!
www.ericthecarguy.com > Troubleshooting FAQ
Learn about the most common causes of engine idle problems and how to determine their source ... Honda Rough Idle ... If you have a check engine light on for any for the above sensors, repair that fault first, then recheck for your idle problem.
How To Fix Or Prevent Stalling, Surging Or Rough Idle ...
? 16:38
https://www.youtube.com/watch?v=Q7gAwGlJAww
Sep 22, 2013 - Uploaded by Old750
This is how I solved the rough idle and stalling problem on my Mazda ... Fix my car, repair my car, advice, help, how to, how tofix my car, help to ..
Nov 15, 2015 | Cars & Trucks
2015 Polaris 900 won't start. Was starting with fast idle, rough running with backfires, now won't start at all. Was running perfect.
fast idle start usually indicates an air leak somewhere.check carburettor bolts are tight and engine head bolts are tight.try that first
Feb 19, 2015 | Polaris 2015 Ranger XP 900
Datsun 1200 motor
BACKFIRE TROUGH EXHAUST IS A VALVE TIMING ISSUE!
WHILE ON THE POWER (EXPLOSION) STROKE...EXHAUST VALVE IS OPENING TOO SOON ...WHILE FLAME PATH IS STILL IGNITED, SENDING IT OUT EXHAUST. I WOULD PERFORM A VALVE ADJUSTMENT AT A MINIMUM
Jul 05, 2013 | Motorsports
Rough idle on 1986 honda civic 1.5 carb
CHECK FOR VACCUM LEAKS , BROKEN HOSES , OR DISCONNECTED HOSES ON THE MANIFOLD OR CARBURETTOR .EVEN A DIRTY CAB CAN CAUSE THIS SYMPTOM .
Jul 31, 2012 | 1986 Honda Civic
I have a 1990 corolla carburettor. When its at normal operating condition the car jumps and runs rough. When you accelerate the car runs well. It only plays up when at idle. But when cold it runs very...
Mar 21, 2011 | 1990 Toyota Corolla
Briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Aug 20, 2009 | Briggs & Stratton Garden
Recurring Mystery Problem in a 1986 Suzuki Alto. (Idle related)
Bad fuel, water in the fuel, dirt in the fuel.
Drain the fuel tank completely.
Pour in a gallon or two of fresh fuel.
See how it goes.
Put some of the old fuel in a glass bottle, hold it up in front of a light and see if you can see any foreign material in it...
Aug 19, 2009 | 1989 Suzuki Swift
Fiat uno struggles to idle on its after i have warmed it up using
Would this be the 1108cc or 1372cc model Uno ? You will find the vacuum advance unit attached to the distributor. Check the pipe connection from the vacuum advance to the carburettor - loose or damaged. This is normally the main cause for uneven idling/stalling. Alternatively the carburettor needs adjustment via the carburettor idling screw. Hopefully this will help. Good luck.
Jun 09, 2009 | 1985 Volkswagen Jetta
83 toyota p.u. 4x4 running rough.
I think you must have the carburettor plunger not going well as you are getting flat spots under sudden acceleration, I think the best way to go is to get the carburettor overhauled.
Dec 15, 2008 | 1983 Toyota Pickup
Garden Logo
12 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
