Question about Car Audio & Video
450W Amplified Boom Box With 10'' Subwoofer Led Grille US005 manual
    Problem Solver:
  • 16 Answers
What is the brand?
Posted on Aug 09, 2009
What's the watts for a boss audio systems BA-1200
Here is the manual with all the specs for the BASS1200 10" Low Profile Amplified Subwoofer
http://www.bossaudio.com/manual/index.php?dir=&file=BASS1200_EN_UM.PDF
Sep 16, 2015 | Boss Car Audio & Video
How can you tell if a tsunami subwoofer is blowed
It will either produce a distorted bass sound or no sound at all.
Apr 25, 2013 | Tsunami 12" Subwoofer Speaker Chrome...
Need speaker box Measurements for a 10 inch 8 ohm kicker comp
Look in the manual that comes with your subwoofer. For most 10" subwoofers, you need to make sure there is at least 1" to 2" around the subwoofer for the front plate. And the figure out how you want it to sound for the depth of the box. Slimmer box equal higher bass, wider box equals deeper boom. You always want to account for the thickness of the wood. If it's thinner wood you won't have that deep of bass. If you have thicker wood it will give a richer sound. Mainly if you building a single box you need at least 12"X12"X12" would be just fine. It gives plenty of room for everything to fit and you can just fill it with foam to make the bass sound deeper.
Sep 20, 2012 | Car Audio & Video
Could i wire my audiobahn Eternal subwoofers to my surround sound system?
is your subwoofer self amplified? if it has, you can connect it through audio sub output and in put to your self amplified subwoofer.. if it is not self amplified, you can still connect it but be sure it ca drive your subwoofer, it depends on RMS or watts of the original sub of the srround..or you can have a seperate amplifier only for your subwoofer. "Audio out - Audio in"
Aug 10, 2012 | AudioBahn AWES12P Car Subwoofer
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
Jul 07, 2009 | Bose Acoustimass 16 Speaker
HOW TO INSTALL
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Jan 13, 2009 | Pyle 12" 600 Watt Amplified Subwoofer Tube...
My car stereo shuts off when i adjust the volume of my amplified subwoofer
your power suplly is either not good meaning the power cable is too small or you don not have enough ground. try adding a bigger cable for ground and power (dc).
Aug 12, 2008 | Pioneer MONO CAR AMP 1000W X 1 Car Audio...
Audio Out Fixed/Variable
Is your subwoofer amplified or passive?
You clearly understand that you need to use a variable line out to control the subwoofer volume via the TV. As the setup seems reasonable, I'm wondering if the subwoofer is getting a signal, but that it is at line-level and not internally amplified by the subwoofer speaker. Generally, if the subwoofer must be plugged into an AC socket in the wall, it has an internal amplifier and can be fed line-level audio. If it is "passive", it has no amplifier, and it must receive an amplified signal (over speaker wire) from an amplifier (or integrated receiver). TV's don't generally have connections to send out an amplified signal.
If the subwoofer is indeed amplified, then this is obviously not the problem, but it's the first thing to verify given the information provided.
Mar 15, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Car Audio & Video Logo
166 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
