To stop auto adjustment in progress on my desktop
SOURCE: auto adjust in progress
if you tell me that you've reinstall the vid card software .
it might have be your video board in your LCD that have trouble you.Up to certain of time of your usage the component get heatup it get shorted. Try to get video board replaced.
SOURCE: auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
SOURCE: My HP w1907 won't stop popping up 'Auto Adjustment in Progress'
Something seems to be triggering it to restart, these are some of the things you can try. Make sure your video cable and power cord are secure on both ends. If you have video card make sure it is secure in its socket. Try plugging the power cord into a different outlet. Try it on another computer if possible. If you find nothing with these ideas I would send it back if it is under warranty the power supply seems to be dropping out.
SOURCE: Auto Adjusting in progress keeps popping up?
Might be a loose connection, a bad cable, or a bad video card. I'd try the monitor on a different computer--even a laptop. Should give you an answer as to what's wrong. With the laptop, reboot it with the video cable attached.
