Question about Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car Speaker
Toyota townace rear speaker connection location
Toyota Camry 2003 V6 radio
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 16, 2016 | Toyota Cars & Trucks
Toyota townace service manual
How many litters of Ingine oil of Toyota townace
Mar 15, 2012 | Toyota Cars & Trucks
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 29, 2011 | 1990 Toyota Celica
Hi i need to know where the indicator relay is on my toyota townace 1985 model / can you help ,thanks
For 1985 Toyota Truck Van 2.0L FI 4cyl the Flasher is located: Front seating area, driver side, under dash, mounted in fuse panel .
Hope help with this.
Aug 08, 2011 | 1993 Toyota Previa
I just bought Alpine car stereo CDE-100EUB but I'm having trouble connecting it to my old car toyota Rav 4 2004 model because the wire harness are different. also the alpine wires are more in numbers than...
Please let me know if you have any questions, and thanks for using FixYa.
2004 Toyota RAV4 Car Stereo Radio Wiring Diagram Alpine wire color
Radio Constant 12V+ Wire: Blue/Yellow yellow
Radio Ignition Switched 12V+ Wire: Gray red
Radio Ground Wire: Brown black
Radio Illumination Dimmer Wire: Green none
Radio Antenna Trigger Wire: N/A blue
Radio Amplifier Trigger Wire: N/A blue/white
Left Front Speaker Wire (+): Pink white
Left Front Speaker Wire (-): Purple white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Blue gray/black
Left Rear Speaker Wire (+): Black green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Red violet
Right Rear Speaker Wire (-): White violet/black
Jan 02, 2011 | Alpine Car Audio & Video
I need the wiring colors for a after market radio harness for a 1997 toyota 4runner withe the premium radio
here to your 1997 Toyota Camry. Radio Constant 12V+ Wire: Blue/Yellow
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Right Front Speaker Wire (+): Green
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Nov 05, 2010 | Toyota 4Runner Cars & Trucks
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Recheck your wire connections, good luck.
Thank you for using Fixya
Mar 19, 2010 | 2002 Toyota Tacoma
Overheating 1991 toyota townace
most engines the thermostats let water out into the top hose . toyotas thermostat is fitted in the engine block letting the water into the bottom hose. water goes the opposite way around.
Jan 15, 2009 | 1991 Toyota Land Cruiser
Toyota corina
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
Rear Speakers Location: Rear Deck
Oct 03, 2008 | 1990 Toyota Corolla
Car Audio & Video Logo
54 people viewed this question
Top Audio Pro Car Audio & Video Experts
xxxxxx xxx
Are you an Audio Pro Car Audio and Video Expert? Answer questions, earn points and help others
