W32ART.POD I don't where download W32ART.POD
I would like to add my i-pod to the receiver so i could listen to the music what kind off cable would i need
An i-pod provides a standard headphone level output. The AVR-1803 has nine RCA stereo inputs that will accept the signal from the i-pod. You need a 3.5mm stereo TRS plug on one end and two RCA plugs on the other end to connect your i-pod to your amplifier. Note: Be careful to select a 3.5 mm plug that has a slim enough plastic moulding to fit into the i-pod headphone output. On your amplifier you simply select the analogue input that you have chosen to use. Be careful of levels when you are setting up. Set the volume of your i-pod to about 50% and set the input sensitivity to zero, press play on your i-pod and gradually increase the gain on your amplifier input. Hope this helps, Don.
Dec 08, 2013 | Denon AVR-1803 Receiver
I want to donload music on my ipod nano and i don't know how to
Hello
Download and install i tunes on your pc or laptop.Here is a link.
http://www.apple.com/itunes/download/
Once you have i tunes installed.Make a file of music in i tunes.Then use a usb connector and plug in your nano.
Drop and drag the songs you want onto your i pod from i tunes.
May 08, 2011 | Audio Players & Recorders
I have a suunto pc pod. my suunto t3d watch can connect to the pod but the pod cannot connect to the software installed (training manager lite) since my pc cannot find any drivers to install for the...
I found out that this is because the wrong drivers are installed.
When you install the suunto software the usb drivers are stored under C:\Program Files\Suunto\USBDriver. This contains more than one driverset. See if you can find this.
Then go to Control Panel\Hardware and Sound\Devices and Printers and find your Suunto device. You probably have only one device and will miss Suunto Usb Serial Port.
Now open the deve and change the drivers, via manually select . Select browse and go to C:\Program Files\Suunto\USBDriver. Press Enter. The program will see that there is more than one driver set and offers you a choice.
Previously it has automatically selected the newest one, which unfortunately did not work in my case. Select the oldest set and the program will install the drivers,
Now you will see in Control Panel\Hardware and Sound\Devices that you have 2 devices suunto pc pod and suunto usb serial port. And the program will run and be able to connect to the watch
Good luck
Timco
Oct 02, 2010 | Suunto Pc Pod Wireless Transmitter
Connection to I Pod touch from PC desktop computer Unable to connect
1.- You must verify that the desktop computer works without problem in wireless way with the D-Link device.-
2.- The I Pod touch device is an external unit to the desktop computer, so you have be shure of the first condition.-
3.- If the destop computer don`t work in wireless conditions, the fail is in the configuration of the LanWireless, you must check both, D-Link device and computer configurations.-
4.- If the computer works ok, the problem is only in the I Pod touch only.- You muts to check fisical connections and I Pod hardware.-
Sep 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
How can i download songs in my ipod?
visit the link below, it will guide you on how to download songs to your I-pod.
Make sure you read and follow instructions and you won't have any problem downloading songs into your I-pod.
http://www.wikihow.com/Upload-Songs-to-an-iPod
Good luck.
Apr 13, 2010 | Apple iPod touch
Download music from my computer
If you want to download to your i pod,you have to use a i Tunes media player to enable you acess to i pod and transfer music into it.
If you don't have i Tunes software, go on net through google an search for i Tune downloads.
Download i Tunes and install,after installing connect your cable from your i pod to your pc.from there you can fnd your way out.good luck.
Jan 21, 2010 | Apple iPod nano
Unable to load MP# files from memory stick on to iPod
You should go to www.limewire.com and downlaod limewire and manually download each song and it'll help you have the music in your i-pod. Yoy can also open i-tunes and connect your i-pod home of your i-pod and check the box that says manually manage songs but that will erase the music you have in the i-pod but will allow you to put the mp3 files on the i-pod.
Apr 18, 2009 | Apple iPod nano
Need xp driver download for gogear model # SA5125/17
Dear Sir/Madam,
I have problem in my I Pod 1 GB gogear that My CD is lost & Window is curropt . So could u provide me the CD for repair of window for My I Pod on chargeable basis
Regards,
Sanchit Kumar
# -9911879497
New Delhi
Sep 29, 2008 | Audio Players & Recorders
Downloading
First of all which music programme are you using to connect your Ipod. Nano will only work with itunes.
Jan 08, 2008 | Apple iPod nano
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
