Question about Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
Tecnik oven fan does not turn off
Oven fan does not turn off
4 Suggested Answers
  • 3 Answers
SOURCE: Tecnik 8525 Oven
Press and hold the start cooking and end cooking buttons together while adjusting the clock with the + and - button. Once the clock is set you will not have a problem
Posted on Dec 11, 2007
  • 1462 Answers
SOURCE: Tecnik TKC 1285 Access to Fan Element
both. element is usually held by 2 7mm nuts on posts from element base plate which are accesible from rear plate. element comes out into the oven cavity
Posted on Jul 14, 2008
SOURCE: TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Posted on Mar 30, 2010
Tecnik Range dual fuel TKC 1285 (more than 10 years old) The timer clock doesn't work so we cannot set the timer for the oven to come on later in the day + Our oven doesn't work when we...
No you can replace timer or bypass it to make it work. I can source parts for you I and fit if required. David 'The Famous Forry'
Oct 20, 2017 | Tecnik Ovens
Main oven trips electric when switched on top oven works fine also grill . did notice that fan was making a noise
If the fuse or circuit breaker is tripping it is most likely a short circuit in the oven element.
Feb 09, 2011 | Tecnik TKC8082 Electric Double Oven
There is a loud buzzing from our Tecnik 1285 range cooker. The buzzing starts about 5 minutes after turning either of the ovens on, and only stops 10 minutes after turning it off. The front of the oven /...
its the cooling fan to keep the control and metal and top of cooker cool. mine is also extremely loud. I think it basically turns unecessarily quickly and could be slowed with a resistor in line
Jan 20, 2011 | Tecnik Ovens
I have just replaced a fan oven element on my Tecnik TKC1285 range cooker. However, the fan now turns off when the oven reaches temperature, and the element continues to operate
Sounds to me like it is wired incorrectly, the fan should continue to run even thnough the element turns off at the correct temperature setting.
You could try reversing the connections to fan and element, this in theory should solve the problem.
Dec 31, 2010 | Ovens
I am struggling to find a spare fan motor REGESA turbo C2-20B for my TKC9475 oven.
This should be the motor you need. Your oven model is not specifically listed, however the same part is used for many Siltal manufactured ovens, I believe yours is one of them.
http://shop.ukwhitegoods.co.uk/Cooker+%252526+Oven+Parts/Brandt+Spares/Brandt+Oven+Fan+Motors/2.12DNB002130+Cooker+Oven+Fan+Motor.html
Tecnik is effectively just a 'badge' meaning there are numerous other 'badged' appliances which share many common parts.
I would advise you verify this with UKWhitegoods before ordering just to be sure. You can email them on sales@ukwhitegoods.co.uk or alternatively, complete the online help form, which can be found here:
http://shop.ukwhitegoods.co.uk/contact_us.php
I have used this supplier many times and recommend them. They answer enquiries quickly, always give the correct information and delivery times are excellent.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Nov 27, 2010 | Tecnik TKC9475 Stainless Steel Dual Fuel...
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
Jul 13, 2008 | Tecnik TKC1285 Dual Fuel (Electric and...
Dec 19, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Tecnik 8525 Oven
Dec 06, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Kitchen Ranges Logo
44 people viewed this question
Top Tecnik Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
