Question about Acer Aspire Computers & Internet
Will not import photos from card reader - Aspire Acer Computers & Internet
    New Friend:
  • 53 Answers
If you explain in detail what you are doing and what results I might be able to help.
Posted on Apr 21, 2014
Galaxy Tab OTG Connection
SAMSUNG GALAXY TAB USB OTG CONNECTION CARD READER
With the Galaxy TAB OTG Connection, you can easily download the photos from a digital camera or from a USB Flash disk straight to your Galaxy Tab and share them with your family and friends.
The reader has 3 Connector each with a different interface:
1. USB Port can connect to the digital camera, USB mouse, USB Flash Disk, etc. It also support external keyboards.
2. Using the SD(HC), MS card reader imports photos from your camera straight on to your Tab.
3. Using the TF, M2 card reader, photos from your camera will be directly transferred straight on to your Tab.
Your Galaxy Tab will automatically open the photos after you make a connection and you can then choose the pictures you wany to import.
Jul 11, 2013 | Android Apps
How do I import photos from my camera?
There are two ways to import your photos.
One, your camera should have an sd card which you can eject and put into your computer. The sd card should have all your photos and videos in it. Typically the card is located near the battery and you can press down on it and it should pop out. You may also need a sd card reader or micro sd card reader if it doesn't fit in your computer.
Second, your camera should also have a usb port, whether micro or mini or whatever. It should have a port to connect to your computer through a usb cable. In this case, just connect your camera to your computer and it should show up on your computer like an extra drive where you can go in and see all your photos.
Also, the folder that holds everything is usually labed DCIM i believe.
Hope this helps.
Oct 26, 2012 | Cameras
How do I transfer photos with sd memory card reader to my computer ?
insert your memory card to the sd reader then insert to your computer port .. and then open any image viewer app then import. you should get picasa image viewer
Sep 27, 2012 | HP Omni 100 PC
Pictures will no longer upload to my pc
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 22, 2012 | Pentax Optio Cameras
Can't upload photos to pc
Jul 22, 2012 | Pentax Optio E30 Digital Camera
How can I import only the latest pictures on my memory card without importing all the pictures that are on the card
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy only the photos you want to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 31, 2012 | Canon PowerShot A3100 IS Digital Camera
Import photos from memory card
If you have a memory card reader then you need to do the following:
1. Insert your memory card in a card reader.
2. Give it sometime to install then go to MY COMPUTER
3. Select MEMORY CARD
4. Then there will be a folder named DCIM select that folder
5. There you will find all your pictures.
6. Select all your pictures by pressing CTRL + A (to select all)
7. Then CTRL + C (to copy)
8. and paste it where you want to save the pictures.
Jan 01, 2012 | Kodak EasyShare M853 Digital Camera
The photos are on my card and I cant get them onto
Using the card reader...when you plug in the USB cord, doesn't a "noname" icon appear on your screen?
Oct 18, 2009 | Nikon D70s Digital Camera
Coolpix L20 usb cable will not work
The cable itself might be to blame. You should hope so, since the alternative is not good news. These cables are pretty much standard and available in any Radio Shack or Best Buy.
If that doesn't work (and you can return the cable if that's the case), I would recommend getting a cheap card reader rather than using the camera and cable to import your photos. Your camera takes SD and SD-HC cards. To be safe, you should be sure to get a card reader that can accept SD-HC cards (not all of them can).
With a card reader, it's even easier and faster to import photos. You insert your memory card into the reader, which attaches via USB on your computer, and it shows up just like a disk drive. then drag and drop your photos where you want them.
Sep 12, 2009 | Nikon COOLPIX L20 Digital Camera
Importing photos (previously successfully)stops
One way to solve problems like this is to use a card reader/writer. This will get your pictures to the computer from the card reader which appears as another drive. Most newer card readers need no drivers.
If you still want to use your camera to copy files to the computer, then you should uninstall the program and re-install according to the instructions.
Sep 02, 2009 | Kodak EasyShare C613 Digital Camera
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
