Question about Hayward Industrial Products Hayward EcoStar Variable Speed Pump SP3400VSP
Just ran new wire to new hayward sp3400vsp pool pump due to a short in underground conduit. there's power to the pump but nothing showing in digital window on control panel. motor wont start. is there a reset button or something?
  • David Spradling
    David Spradling Nov 12, 2017
    have to see if 220 volt or 120 volt see side of motor
    Top Expert:
  • Hayward Indu... Master
  • 6,394 Answers
If voltage going to pump motor maybe spike took out control board on pump motor if correct voltage to unit bad pump motor
Posted on Nov 16, 2017
  • 5,245 Answers
The short might have caused overheat and damage to the electronics.... contact hayward
Posted on Nov 14, 2017
I have a Hayward sp3400vsp. The pump runs all night some times, the screen say is priming, it will shot off manually, and it wont do it all the time. help??
Sounds like the pump is sensing that there is a problem with water flow on the suction side.
Could be caused by air being sucked into the system. Do you notice air in the strainer chamber? Or bubbles coming from the inlets in the pool?
Could also be caused by something clogging or restricting the suction line.
May 31, 2014 | Hayward Industrial Products Hayward...
Why does my pool light trip the breaker ?
either water in light or in conduit break in wire or water in access boxes
Jun 29, 2012 | Hayward Pool & Spa
The capacitor is burned and i think thas the problem why the pumps doest'n star
Is there power to the pump or is a breaker being tripped? Find out where, exactly, the power is out. It could be loose wiring in the conduit or a loose connection where it wires into the motor. Many things.
www.cpo2go.com
Dec 02, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Just wired Hayward super pump 1 hp and it ran great for maybe 1 minute. It then began making a series of clicking noises; but, I shut if off before worsening the problem...Please help anybody. What could...
better check the power coming into the pump. Is it 240 or 120?
Double check that you have the correct setting on the motor for whichever amount of power your feeding it.
Is it a brand new pump? If its brand new and you do in fact ave it wired correctly, id return it
Aug 14, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
My circuit breaker feeding the pool light trips every time I try and turn the pool light on.
Is the amperage in the circuit breaker above the rating for the power requirements for the pool lights? If so, is it double tapped and feeding something else at the same time? If not, I would guess a short in your wiring. Usually, the wire travels from the breakerbox underground through piping. If you had it installed a while ago, they probably used emt ( metal piping). That stuff falls apart underground and probably nicked some wires causing the short.
Jul 10, 2009 | Hayward Stainless Steel Astrolite II 100w,...
My new Hayward Super Pump is over Amping
Sounds like the wire gauge (thickness) is to small
Jun 04, 2009 | Hayward Pool Products Hayward Super Pump
Clicking noise in new Hayward Super Pump
It sounds like the wear ring on the impeller is hitting the diffuser. If it is new call Hayward to fix it under warrenty
Best of luck
Jun 04, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward Industrial Products Hayward EcoStar Variable Speed Pump SP3400VSP Logo
199 people viewed this question
Top Hayward Industrial Products Pool & Spa Experts
CrisO
Gene Haynes
David Spradling
David Spradling
Are you a Hayward Industrial Products Pool and Spa Expert? Answer questions, earn points and help others
