Question about Mantis 2-Cycle Tiller
Mathis tiller sv-4 engine no spark form coil - Mantis 2-Cycle Tiller
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
Clean and adjust the ignition points.
Posted on Jun 19, 2009
Honda gx200The water blaster just stopped and I change the spark plug but still only a very small spark that is when it sparks?Coil buggered?
very small spark okay as long as its blue and not bright yellow.try using starting fluid if runs might want to see if carburetor is getting fuel.
Jun 18, 2013 | Honda Engines GX200 Series General Purpose...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
No spark
Hi
You need a special tester to test a coil off of the engine. If you take iit to a small engine shop they can test it for you. You can test it on the engine. First clean the surface of the coil where it mounts to the engine. Reinstall the coil. Do not install the kill wire to the coil. Install a inline spark tester and crank engine if you still don't have any spark the coil is bad.
Sam
Jan 11, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Won't start. have replaced plug and cleaned filter. any suggestions?
check and see if your coil is grounded,if not clean flywheel magnet and check for spark if no spark replace coil,
Jul 28, 2009 | Mantis 4-Cycle Tiller/Cultivator with...
I need to find a place to buy parts for my mantis
Try this site.
http://www.alamia.us/SearchResults.asp?Cat=132
Eric
Jun 24, 2009 | Mantis Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
What is left to do but change the flywheel?
check what they call air gap between the coil and flywheel .010-.012 gap
also be sure your flywheel is in time.
you will actually have to remove it to do this and check for the sheared key or be sure the key way aligns with the crankshaft keyway on the flywheel
May 17, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
387 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
