Free tv repair advice
TV picture disappears, TV goes off. We turn the on/off button off to restart it after bout 1/2 hr goes for about 20-30 minutes red light starts blinking about 3-4 times and then same pattern. We do not have digital voltmeter
    Top Expert:
  • Televison & ... Master
  • 75,452 Answers
Without a multimeter, it will be difficult to proceed. The fault sounds like with its main power supply regulator [SMPS] section circuit itself. Check for any loose solder terminals at this section circuit, and re-solder all the suspected ones by applying a little more solder and check. That is the only thing you can do without having a multimeter to use.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 21, 2014
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
  • 668 Answers
SOURCE: Sony Vega KDF-E5OA10,picture will not come on, tv goes off.
There is a real good chance that the lamp fan is not turning. If you look with a flashlight in the vent on the left side looking at the rear of the set and have someone turn on the unit, see if it spins. if it doesnt, the protect circuit in the tv will not let the set turn on. Replacing the fan will cure the proplem if it is not turning.
Hope this helps,
Skyassoc
Posted on Jun 18, 2009
skotkolr
  • 558 Answers
SOURCE: Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Posted on Apr 09, 2009
SOURCE: KDF-E60A20 Red Light Flashing 6x
a 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
Posted on Jul 09, 2009
  • 7 Answers
SOURCE: TV will not start and power button flashes 10
The 10-1 flash is usually the A board part number TNPH0716ABS
Posted on Jan 26, 2011
My Netflix works up until I press OK, then screen goes black. Thankyou.
Restart the smart TV
Press and hold the power button on the TV remote control for 10 seconds to restart the TV.
If you restart the TV, try Netflix again.
If the TV does not restart, turn it on again and continue with the following troubleshooting steps.
Disconnect the TV from the power for at least 1 minute.
With the TV off, press and hold the power button on the TV for 5 seconds to unload it.
If you can not access the power button or your TV does not have it, leave the TV off for at least 3 minutes.
Reconnect the TV.
Turn on the tv.
Try Netflix again.
Aug 12, 2017 | Cars & Trucks
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Intermittent loss of picture
You'll have to locate the vertical output IC which should be mounted onto a heatsink, then take out a good magnifier under the printed circuit board and examine the solder connections on the pins of that IC and resolder the ones that are cracked.
Mar 12, 2007 | Proscan PS27125 27" TV
This is probably a short in the TV, most likely a ground problem.,, make a proper ground (earth) for the the TV.
that will Fix your problem.
Feb 14, 2007 | Toshiba 57H84 57" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
