Question about 4 X 17" Zito Alloy Wheels & Falken Fk-452 Tyres - Nissan Blue Bird
How do I take off stainless rims from my alloys
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Very carefully a tire shop for a small price can do it for you
Posted on Sep 09, 2014
Need help with Alloy rims
Try oven cleaner that is what I use. Also there are many metal cleaners out there, did you do a google search for products to clean cast aluminum?? Try www.SummitRacing.com
Jun 07, 2016 | Vehicle Parts & Accessories
Magenta cast on left side and green cast on right
We are OEM foundry adopting of advanced sol-wide (colloidal silica)investment casting process,produce castings of various kinds of carbon steel,alloy tool steel,wear-resistant alloy steel,heat-resistant alloy steel and all kinds of stainless steel &it's develped products,with an annual output of 600tons of investment castings production capacity,80% of them were exported to the United States,Germany,Janpan,Spain and other countries.
hot sale pneumatic fittings Pneumatic valve stainless steel casting...
May 26, 2016 | Canon LV-7265 Projector
What is the role of stainless steel products?
Products which are manufactured by stainless steel is mainly depend up on the type and quality of stainless steel means it may be plain, ordinary stainless, like in a handle or pot, then any alloy steel drill will do. On the other hand, if it is hardened stainless like what is used in instruments, you probably will need carbide, although you might get a tool steel drill to make one hole.
Stainless steel is defined as a steel alloy with a minimum of 11.5 wt% chromium content. Stainless steel does not stain, corrode or rust as easily as ordinary steel, but it is not stain-proof. It is also called corrosion resistant steel when the alloy type and grade are not detailed, particularly in the aviation industry. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Common uses of stainless steel are cutlery and watch straps.
For detailed information visit at: Solutions of Stainless Steel Products
Feb 01, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
Alloy rims losing 10-15 psi every 2-3 weeks
hyundai might have a recall on them if you check
Apr 21, 2015 | Hyundai Sonata Cars & Trucks
Dent tire rim
If its an alloy rim... it can't be dented.
Jan 13, 2014 | Vehicle Parts & Accessories
What is standard wheel size for toyota celica 2002 and what sizes will fit
alloy wheels
Wheel Part Number: #69387
2000-2005 Toyota Celica
Size: 15" x 6.5", 5 Lug, 100mm Bolt Pattern
Finish: Silver
Description: 5 Double Spoke OEM Alloy Rims
steel wheels
Wheel Part Number: #69386
Finish: Black
Description: 12 Hole Original Steel Rim
Dec 04, 2010 | Toyota Celica Cars & Trucks
What size alloys. Ford Calypso 1997
Yes. The last number on a tire size is the diameter of the rim, when it changes so too must the tire. The bigger the tire the more they cost.
You also have to pay attention to the width of the rim, side to side. Somes tires need a wider rim than others, so ask when you are buying the rims what width they need tires to be because wider tires cost more too. Hope this helps.
Aug 18, 2009 | 1997 Ford Escort
Every other week i'm getting flat tyres very unexpectedly. The tyre pressure warning light comes on but instantly the tyre is completely flat. Apparently its due to corrosion of alloy rims, how can i get...
A temporary workaround/remedy is to put innertube inside the tire. Even if the alloy rims could not longer provide a good air tight seal, the inner tube would still hold the air. You may need to specify the tire size and width. Additionally, you may want to ask your tireman to likewise install a buffer of some sort between the innertube and the alloy rim. This is to prevent the any sharp portion of the corroded alloy rim puncturing the inner tube. Some local tiremen use a cutoff/old inner tubre as buffer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 15, 2008 | Mini Cooper S Cars & Trucks
Stainless steel?
There are many (>100) standard stainless steel alloys. The most commonly used stainless steel alloys in appliances are "austenitic" - these have a higher chromium content and added nickel. The nickel modifies the physical structure of the steel and makes it non-magnetic.
Nov 04, 2007 | Kenmore 15073 Stainless Steel Built-in...
4 X 17" Zito Alloy Wheels & Falken Fk-452 Tyres - Nissan Blue Bird Logo
Top Bella Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Bella Vehicle Part and Accessory Expert? Answer questions, earn points and help others
