Question about HP Office Equipment & Supplies
Communication with selected server is lost when sending image sharp
4 Suggested Answers
SOURCE: Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Posted on Dec 19, 2008
  • 46 Answers
SOURCE: Our Sharp copier MX3501 is
The scan location (i.e. email, ftp, network folder, computer with sharpdesk) can't be found check the address details and make sure they are correct.
If it is a sharpdesk scan then the most likely reason is that the IP address of the computer has changed (DHCP).
If FTP or Email check the address of the server you are sending to.
Your IT or Service provide should be able to help give you the correct addresses and authentication settings for these.
Posted on Oct 21, 2010
  • 120 Answers
SOURCE: "Communications with selected server is lost while
Go into your web page and make sure your SMTP IP addresses and domain name entries are correct. Also check your DNS IPs and make sure they are current. You also may need to authenticate (name/password)
Posted on Feb 24, 2011
Feb 02, 2011 | Sharp MX-3501N All-In-One Printer
We brought sharp ar-5316 oneyear back.Now servers and desktop has migrate to redhat linux.so i need printer driver for redhat linux.
How was your day, hope fine. Sharp Ar5316 driver are for windows. This means that the printer drivers are only compatible with windows and not with linux. My advice to you is that please uninstall Linux system from your desktop and servers and install windowsxp instead and your copier will work. Remember to save important files while doing this as they may be lost in the process. Let me know your progress.
Nov 26, 2010 | Sharp AR-5316 Advanced Digital Imager...
Our Sharp copier MX3501 is sending a message that selected servers cannot be found. How do we correct?
Oct 21, 2010 | Sharp Office Equipment & Supplies
I can not set up my system with windows seven 7 please send softwere for my syetems . my sestem is sharp AR5316E
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
Photocopiers > AR5316E > Windows 7 (32-Bit OR 64-Bit)
Hope it helps! Good Luck!
CreativeTECH
Sep 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am an IT pro who has an AR-M355U. We are having a problem with some new email addresses we entered. We changed the suffix of the address to a new service, and the decive stopped sending scans to our...
CE-O3 = The specified server suspends reponse during transmission of images.
Cause: Improper connection of the network cable, An error occurs in the SMTP server/FTP server/ NTS
Check: Check that the network cable is properly connected.
Check the SMTP Server/FTP server for any trouble.
Aug 23, 2010 | Sharp AR-M277 Black and White Copier
How can I print a transaction report for faxed items
Press SYSTEM SETTINGS
select Admin Password and enter the password as "admin" and OK on both screens
Scroll to LIST PRINT (ADMINISTRATOR)
Select IMAGE SENDING ACTIVITY REPORT and select FAX. This will print out the log up to a maximum of 200 events ( Tx, Rx and failed sendings)
If you want a transaction report printed for each individual transmission:
Enter Admin mode as above
Got IMAGE SEND SETTINGS
FAX SETTINGS
TRANSACTION REPORT PRINT SELECT SETTINGS and select Single Sending / Broadcast etc and PRINT OUT ALL REPORT
Press OK then CA to exit
Feb 18, 2010 | Sharp MX-2700N Color Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Sharp arm 450n (ce-02)
1) If you're actually scanning to an email address, make sure your SMTP email server information in the copier's web page is correct.
If you are using names instead of IP addresses, also make sure your DNS server IP's are correct.
2) If you're scanning to create the fake email set up by Sharp Network Scanner tool, the connection info in your copier is old and needs to be refreshed.
From the computer you're trying to scan to, right click on the Network Scanner Tool icon in the tray, go to Automatic Profile Update, and select Update Now. If you have no tray icon, reboot your computer.
If your copier is set up to store names instead of IP addresses, make sure your DNS information is correct in the web page.
Jun 30, 2009 | Sharp Office Equipment & Supplies
Nov 21, 2008 | Sharp MX-2300N Color Copier
Sharp Copy Machine
You don't say if you are using a server/client network or a peer-to-peer. Go to START >printers and Faxes >Add a printer >Next and select A Network printer select Connect to the printer and then enter the path to the printer eg \\server\printer name
Oct 01, 2007 | Computers & Internet
190 people viewed this question
Seeker5211
Seeker5211
