Question about Refrigerators
Dometic repair LID WILL NOT STAY UP
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Why won't Microwave door stay shut?
We are having the same problem. Seems like latch spring is broken. We can not find any parts for this. Dometic is 3 yrs. old so no warranty. No service for it either. Keystone really took us on this
Jul 06, 2014 | Dometic DOTRC17B RV Microwave/Convection...
Why does the Dometic 15000 BTU RV AC Unit cycle on and off in short bursts?
I had the same problem with my 2013 Alpine! I took it to a Keystone dealer and of course it wouldn't do it for them, so I contacted Dometic 574-294-2511 and asked for Al McGuire! (GREAT GUY) He is the guru of Dometic! I live 50 miles from the nearest dealer and he sent a new pc board AND a new wall thermostat to an appliance repair shop at no cost! "I" replaced them ( 5 minute job) and it has been working fine. I do keep my fingers crossed because the thermostat is terrible to program.
May 29, 2014 | Dometic Rooftop RV Air Conditioner
2003 Accord trunk lid will not stay up
the tension spring maybe broken or slipped off
Nov 29, 2012 | 2007 Honda Accord Sedan
On my dometic refrigerator, modle# rm36e, prod # 9264530, ser # 7090209 the piolt lite will not stay on when I let go of the button
Just like with any older pilot light gas appliance, your refrigerator has a thermocouple which senses heat from the pilot and sends an electrical signal to the pilot valve when it is properly lit. I suspect this thermocouple has gone bad. It will look like a probe sticking into the area of the flame from the pilot and will unscrew from some sort of mounting bracket and have a wire on the other end that plugs into a connector. Generic versions may be available at home appliance repair centers but original replacement would be the best choice. RV repair centers and supply stores will carry it. Do an online search for RV repair supplies or more specific search for Dometic repair centers.
Apr 04, 2012 | Refrigerators
Model 211 Dometic, can not keep pilot lit, do I have to have it hooked up to 12 volt
Dometics work on propane, 12 volt or 110 volts, if pilot won't stay lit then you prob have a control board defective. Apply 12 volts and see if pilot stays lit, then you will know.
Oct 16, 2009 | Dometic Refrigerators
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
