Question about ASUS PadFone Infinity
I got the problem with then battery of my ASUS fonepad wish means when i plug on the charger the ? out on the battery signel.
On asus fonepad how do i cancel call forward
Hi Phil,
Please speak to your network operator to cancel call forwarding for you or they would give you a command which you would need to enter in your device dial to cancel the same if the software is not allowing it.
Hope that helps !!
Jul 11, 2014 | ASUS FonePad
HELP!My Fonepad cant auto rotate!
Go to settings>display and make sure the autorotate is enabled. If it still isn't working then there may be an issue with your device's accelerometer, test it in a game such as temple run.
Mar 31, 2014 | ASUS FonePad
Battery level 0
Have you tried shutting it down completely an then restarting. It solved my problem
Mar 24, 2014 | ASUS FonePad
Will installation of a asus miracast dongle allow me broadcast from my asus s400ca to my LG TV wirelesslyasus asus support
ASUS Miracast Dongle lets you experience Full HD wireless entertainment and lets you stream your favorite movies, videos and photos through to any compatible large screen TV. Easy to set up and play, Miracast Dongle supports dual-band wireless (2.4GHz and 5GHz) and HDMI to ensure no latency in signal transmission.
  • Compatible Model ASUS MeMO Pad HD 7/ME173X
    ASUS MeMO Pad FHD 10/ME302C
    ASUS MeMO Pad FHD 10 LTE/ME302KL
    Nexus 7 (2013)/ME571K/KL
    ASUS Transformer Pad/TF701T TF103C
    ASUS Fonepad 7 /ME372CG
    ASUS MeMO Pad 10/ME102A
    ASUS MeMO Pad 8/ME180A ME181C ME181CX
    ASUS MeMo Pad 7/ME170C ME176C ME176CX
    ASUS Fonepad Note6/ME560CG
    ASUS FonePad 7/FE170CG
    ASUS FonePad Pad 7 Dual SIM/ME175CG
    ASUS The new Padfone Infinity/A86
    ASUS VivoTab Note8/M80TA
    ASUS Transformer Book/T100
    ZenFone/A400CG A450CG A500CG A501CG A500KL A600CG
    PadFone mini/PF400CG
    Padfone S/PF500KL
ASUS Miracast Dongle Specifications
Feb 06, 2014 | Computers & Internet
My asus fonepad battery is not charging and not tablet is not starting a ? is appearing inside the battery sign
you may change the charger, also check the connectors else you need to replace the battery
Oct 30, 2013 | ASUS Computers & Internet
96% plugged in, not charging Hi all, my Asus
Laptop battery do have a specific lifespan, specially for older units. Still, you can check that your charger are working properly, using a voltmeter (do check the outer label of the charger for actual voltage output).
You may try to do my Tips on Laptop battery
Good luck
Tedmac
Oct 17, 2013 | ASUS Computers & Internet
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Nov 12, 2010 | ASUS A9RP Notebook
ASUS PadFone Infinity Logo
12 people viewed this question
Top ASUS Cell Phones Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you an ASUS Cell Phone Expert? Answer questions, earn points and help others
