Question about Kenmore Microwave Ovens
Kenmore 3850w voltage of equipment is 110 V but the voltage in my home is 220V. what type (vA) of transformer i have to buy?
    Problem Solver:
  • 18 Answers
Voltage in your is probably 120/240 just find an outlet that matches your plugs configuration and check with a voltmeter if unsure
Posted on Apr 22, 2014
Can a microwave be repaired?
Yes it is repairable, but if you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. If light and turntable works than low voltage circuit (220V or 110V) works well. In this case the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or in the main board. If light and turntable does not work than fault could be in power supply elements like: power supply cord, transformer, power board, fuse (glass or ceramic, ussualy 8A, 10A or 12A) on power board.
Dado
Oct 24, 2015 | Kenmore Microwave Ovens
HOW TO USE CUSINEART GRIDDLER WITH 110v TO 220v
Get a step down transformer/converter. Grill consumes 1500watts of energy. Converts cost 200 dollars here at sim lim tower/square. Make sure get the correct watts, it is very important.
Apr 06, 2014 | Cuisinart Microwave Ovens
Microwave don't work but oven do what's wrong
check the voltage micro runs on 110 oven 220v
Apr 03, 2013 | Microwave Ovens
I bought my kitchen aid at the US it's 110v. I plugged it at 220v. Now it still works but not on bread mix
A device which is designed for 110 volts MUST NEVER be used into a 220 volt outlet. This can damage the unit and make the motor winding burnt.
You need to buy a STEP DOWN TRANSFORMER with a good rating (220volt to 110 volt) so that the unit works perfectly without damaging the motor.
Sep 10, 2011 | Microwave Ovens
I bought my nespresso magimix in France and now I am living in japan. It's humming quietly but not making any coffee. Would ot have anything to do with the voltage?
Hi, I would say so. You may have to get a voltage ( transformer). France they have 220v and in Japan they have 100v . Good luck.
Aug 12, 2011 | Microwave Ovens
My country use the 220 volts system do have to use a step down transformer of plug it in direct.it has been a year i have not used the appliance having no information on wattage
If your microwave is wired for 220 volts AC and your country standard house current is 220, and the plug is of the proper configuration, plug it in.
Standard microwave size is around 1100 watts at 110 volts Normally, two times the voltage is 1/2 the wattage. Ohms law, Voltares Law and Watts Law apply.
If your microwave is 1100 watts at 110 volts --- yes you will need a step- down transformer of some type.
Jul 12, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
How can use USA microwvave in UK WITH 240VOLT TO 120VOLT 1400WATT
Unless the microwave oven is equipped with either an auto-transformer (which automatically compensates for the input voltage), or has a switch that you can change the voltage from 120VAC to 240VAC, you will need to buy a small step down transformer that plugs into the wall, and then you plug the microwave oven into. Keep in mind, however, that the frequency of the A/C voltage in the U.S. is 60hz. In Europe its usually 50hz. What this means is even if you are able to step down the voltage to use the appliance, the time will not be accurate. You will lose about 10 seconds per minute. Or, 10 minutes per hour. Something you may want to consider.
May 31, 2011 | Panasonic NN-T664SF Microwave Oven
How can i convert our 220 volts wall outlet to 110 volts for a microwave oven.
Find the breaker for it (a double for 220) and substitue a single breaker (for 110). This will leave one wire unused from the breaker box to the outlet. You'll have to change the outlet of course to accommodate a normal 110 plug. You can also skip the breaker part and just change the outlet and cap off 1 of the hot wires. Just make sure to kill the power and be safe!
Mar 11, 2010 | GE JVM1650 1000 Watts Microwave Oven
Kenmore microwave doesn't heat up
I have the same microwave kenmore 721.62624200. I bought it 5 years ago and the same thing happened. It started humming and it's not heating. All of a sudden this just started happening. Is it worth fixing it?
Feb 24, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
