Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Pilot light stays on but burner doesnt ignite
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
Usually the small opening on the burner that 'points' to the pilot light will get clogged with cleaning soap or spills. Look carefully (the burner may be very easy to remove for inspection. There should be a small hole on the side pointing toward the location of the pilot light. It will be lower down than the main burner openings. Clean it out with a wooden toothpick.
Posted on Jun 19, 2009
4 Suggested Answers
  • 189 Answers
SOURCE: Pilot light goes on but won't ignite main burner?
What kind of heater? is it a gas furnace?
Posted on Mar 08, 2009
SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Posted on Jul 18, 2008
  • 3328 Answers
SOURCE: main burner will not ignite Tempstar(NTC5075BFD1)
try cleaning the pilot oriffice it sounds like the flame is weak
Posted on Jan 17, 2009
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
Laars pool heater's burner wont stay lit
Check the burner, the holes may be plugged, especially at the beginning of the season. Same happens to the pilot light tube. Spiders love to make nests inside those small holes clogging everything up.
Aug 13, 2014 | Teledyne Laars Pool & Spa
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot light will not ignite water heater
the pilot light serves to purposes. it is the source of ignition for the main burner and is a safety device that detects wether there is a flame or not. if the pilot light stays on when you stop pressing the pilot light button then you need to turn the knob to the on position to light the main burner. the pilot light is not the on position. if the pilot light goes out when you stop pressing the pilot light button then the thermocouple or flame sensor needs replacing. good luck
Nov 30, 2013 | Raypak Pool & Spa
Raypak 403A, burners will not stay lit for more than a few minutes.
i'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Jun 09, 2017 | Pool & Spa
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Starting a Regency fireplace: gas is on, I turn the dial to pilot. I am suppose to push the dial in, spark the themocouple and hold it for 30 seconds. My problem is that the dial doesnt push in. The only...
Can you spark it and does it light in the "off "position? Try it and see if when the pilot stays on, you turn it to pilot and the burner ignites.
Sep 18, 2008 | Heating & Cooling
Heating & Cooling Logo
372 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
