Question about Dahon Cycling
Pedal removal dahon cadenza
Remove pedal crank
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: just bought dahon archer not
I Can't find that specific model but wheels-is-wheels. Go online and find the manual for one that looks like yours.
http://www.dahon.com/support/manuals?type=bike&tid=55&title=&submit.x=95&submit.y=28
http://www.parktool.com/blog/repair-help/tire-and-tube-removal-and-installaton
Some other manusl may be helpful on a high level, too./
http://www.dahon.com/sites/default/files/support/manuals/bikes/0/2010/2010_dahon_service_instructions_en_40.pdf
Posted on Feb 23, 2011
Tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Recumbant bike slips while peddling
http://www.youtube.com/watch?v=mVJxs7ALxDM&feature=related
Loose Pedals 1
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm.
Oct 30, 2011 | Nordic Track NordicTrack Treadmill, A2550
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
My Suntour Folding, non-slip pedal has a bad bearing. Where can I buy a new pedal?
There are search engines that will find the answers so much faster than flushing them through Fixya.
Pedals are sold in pairs - any bike shop, eBay. Maybe look on a search engine for how to service the pedal instead of replacing it.
For example...
http://www.parktool.com/blog/repair-help/categories/pedal-service
Jun 14, 2011 | Dahon 7 Speed Folding Bike
I can't remove the pedals - I want to remove these
Be advised the left pedal is left-threaded. Get yourself a nice Park brand pedal wrench.
What fixing nut?
How to:
http://www.parktool.com/repair/readhowto.asp?id=83
Apr 01, 2010 | Shimano America PD-M540 MTB SPD Mountain...
Assembling a Dahon D7...
The manual is available here:http://www.dahon.com/support/manuals.htm It looks like the seatpost and seat are meant to be left in the bike.
Nov 23, 2009 | Dahon 7 Speed Folding Bike
Cycling Logo
Top Dahon Cycling Experts
Dan Woods
Dan Woods
dante
ray gallant
Are you a Dahon Cycling Expert? Answer questions, earn points and help others
