Question about Sony VPL-CS7 Multimedia Projector
I want to replace the lamp but i don't have a remote ? what should i do ?
    Top Expert:
  • Sony Master
  • 74,377 Answers
You can replace the lamp very measly, but, there is a need to reset the lamp time. For that, you should have its remote control. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 21, 2014
Runs about 15 minutes and shuts off
hello!are you sure, there is no "off" timer involved? or "sleep timer" getting pushed on remote control? If not: D.L.P. or L.C.D. projectors might have the lamp on a brink of life. Heats up, then quits. May be the picture was quite dim for a while? time to replace the lamp! get lam with housing! don't try to be smart...! It's very simple task to replace the first, rather than save a 10 bucks and get things messed up. I've seen it many times! You need to know "how to" for bare lamp. no need to special knowledge to replace lamp with housing. Just locate the lamp door, unscrew the door, then lamp and go ahead with installation. If you have an old fashion CRT(picture tube) projector, that's a major job! It might shut down due to numerous issues. As of the faulty parts or solder joints or both. there is no such a remedy for a "big screen TV", unless somebody knows exact cause, make, model, etc.Good luck,Alex.
Feb 01, 2012 | Televison & Video
How do i remove the black box on my screen
don't have the original remote control, I used the time warner control, I just reprogramed to control my tv without the cable box, I put the volume all the way up in the tv, then down to zero, and at the same time I hold the 0 key in the remote control, after that the screen said lamp has been reset to zero, I repeated this step because a lamp red light stayed on, after this only the power green light only stays, when installing the new lamp make sure is all the way in, you can use the white out to mark exactly where you have to push or put in the new lamp, it may not been all the way in, hope this help someone !!
Jan 18, 2012 | Panasonic PT-50LC13 50" Rear Projection...
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
I have a Sony model KDF-e55a20. I just changed the buld but I still don't get any picture all I get is the power on light blinks 3 times. Does anyone know what the problem is?
Sir reset the lamp timer of your unit.
1 Press "Display" on the remote, followed by the 5 button, then the sound up key, and "power on". Do this while the tv is in stand by mode.
2 Then press "jump" 3 times to enter DE service menu.The tv screen will display the total lamp time hours.
3 Reset the the lamp time by pressing channel 3, then mute, then enter.This will return lamp timer back to 0. Hope this may help good day and best regards.
Aug 18, 2011 | Sony KV-36FV26 TV
Orange light is on with the lightbulb... we bought this tv from a friend a year ago not sure how to go about replacing anything, we don't have the manual or the original remote. So any help would be...
As you look from the front the lamp is on the far right side behind a door.
With the door removed (unplug set first) you will find one or two screws that secure the lamp unit (it is a cartridge) with a handle---
This model requires the bulb in the cartridge be removed--they do not sell the complete unit---this requires some care--do not touch face of lamp.
The problem with this model is when you take the cartridge apart and replace the lamp you must get it back exactly as before or the 2 wire plug will not engage when you replace it---
What I am saying is it can be a little tricky to get it in place correctly.
GOOGLE the model number with the word lamp after it and you will find replacements.
SD TECH
May 31, 2011 | Zenith E44W46LCD 44" Rear Projection...
How do I reset Lamp in PT40LC12 with out a remote
After turning on the TV and viewing the message to "reset the lamp" I became frustrated and attempted to shut the TV off by pushing the power button. A message popped up saying "Do you want turn the TV off Yes / no.
I toggled down using the volume/Channel button on the tv to say no. The next thing i know...The TV picture came on and the la,p was reset!!! I really don not know how this happened! but it worked! Thanks for your assistance. Now, i can program a remote!
Oct 23, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Fan does not work, light does
Your remote uses a slightly different band of IR for one and the other functions; lamp or on/off. This IR lamp or the circuit that controls the IR lamp has failed. You will need a new remote.
Hunter is good about making replacement parts available but as you said this is five years old. You may have to look for an after market seller on Ebay and chances are very good you can find a new one there.
Try Hunter first:
From Hunter Customer Care
Email:
Use Our Contact Form
Phone:
1-888-830-1326.
Monday-Friday 7am-6pm CST
Regards,
Worldvet
Jun 03, 2008 | Hunter 27177 Remote Control
Sony VPL-CS7 Multimedia Projector Logo
51 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
