Question about KitchenAid KSF26C4XYY 26.0 cu. ft. Side by Side Refrigerator with 4 Spill Shield Glass Shelves, Humidity-Controlled Crispers, External Ice/Water Dispenser and LED Theatre Lighting: Monochromatic Stainless Steel
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
RL40 SBSW Samsung fridge need the globe replaced. How do you remove the cover? Please advice Adele
  • 884 Answers
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Posted on Apr 26, 2014
The light in my Kelvinator fridge will no longer work, can it be fixed, globe has been replaced , also
Barbara: You can remove the globe and replace the light bulb with an appliance light bulb. If it still doesn't work, try wriggling the socket a little bit with the light bulb in place (so you don't get shocked). If it STILL does not work, yes, a socket can be replaced and rewiring can be done.
May 25, 2015 | Kelvinator Refrigerators
How to remove cover of fridge light to replace bulb
generally there is a Philips screw at the edge of the plastic cover,or sometimes you can squeeze or press in the sides of the cover.Check the make & model and go in line to the company,They usually will have a manual where you can find out the answer.Best of luck.
May 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to replace headlight bulb in 1987 toyota camra
For an 87 specifically, I don't know the answer, sorry. There were at least 3 designs used in the 93-94 models alone. If it is anything like them, you have to either
- press in the plastic barb clip on the centre of the wiring connector at the back of the globe housing, and pull down on the wiring connector to disconnect it. Then rotate the globe holder anticlockwise and withdraw it. Don't touch the new globe glass with your fingers, or if you have, clean it well with metho. Then installation is in reverse. Or for a different design,
- alternatively, unplug the electrical connector. Then turn the hard plastic cover, at the back of the headlight globe holder, anticlockwise and remove it. Then remove the rubber cover underneath. If you are replacing an outer bulb remove the bulb spring clip, first taking note of how it is fitted. On an inner globe there may be a covering socket over the globe itself. Remove that, and the spring clip underneath. Replace the globe. Installation is in reverse, making sure all bits are in position, and the 'lock' mark on the hard plastic cover is facing upwards.
Nov 16, 2011 | Toyota Camry Cars & Trucks
How do you fix a 2008 HYUNDAI SONATA front head light?
The halogen headlight is basically a bulb that is replaced from behind the headlight assembly inside the hood. Hyundai has a cover that keeps moisture and debris out. To remove it, simply twist the cover counter clockwise. Once removed, you should be a locking "bracket" that will resemble a small wire handle. This locks the bulb into place. The handle can be released by "squeezing" it together (on some models, the handle is kept in place by a notch) and pulling up. Once released, you will be able to remove the plug and old halogen bulb.
Once the bulb is replaced, reverse the instructions to re-assemble. Best of luck and thank you for using Fixya! Greg
Feb 17, 2011 | 2008 Hyundai Sonata
I have a maytag microwave umc5100adb (built in microwave) & the bulb burned out. I can't figure out how to access the bulb to replace it. So to the question " Are you smarter than your...
To replace the bulb in most Microwave Ovens requires the removal of the external metal cover to access the globe area. Once this cover is off, (usually held in place by several screws), it is relatively easy to remove the globe and fit a new one of the same type, and then replace cover and all screws.
In your case you will have to first remove the Oven from its built in setup before proceeding with the process as described above.
Jan 10, 2011 | Microwave Ovens
Tail light is burned out on tail light. I have the bulbs but can't figure out how to remove and replace burned out light.
  1. Check with your local auto parts store or look in your owner's manual to find the proper model number of the replacement tail light globe.
  2. Open your trunk or lift your hatchback. Find the cover just on the inside of your vehicle next to the burnt-out bulb.
  3. Turn the two latches counterclockwise to open them so the cover may be removed. In most cases you can turn the latches with your fingers; in some cases you may need a coin or a slot screwdriver to turn them. Remove the cover.
  4. Press the tabs that allow you to remove the tray that holds the tail light globes. There are four tabs on most VW models. Each tab must be depressed to release the tray. Pull the tray out a few inches, as far as the wiring allows.
  5. Press down slightly on the burned-out globe and turn it counterclockwise with your thumb and fingers. It should release easily and then pull straight out. Push the replacement bulb in and turn it clockwise until it locks in place.
  6. Snap the tail light tray back in place. The tray should simply push back into place and the four tabs should "snap" into their locked position. Replace the door cover and turn the door locks clockwise. Test your bulb to see that it is working.
Good Luck
Nov 20, 2010 | 2004 Volkswagen Beetle
License plate bulb replacement 2008 Hyundai accent
go to license plate look above it and you will see the globe or globes remove cover and replace bulb,can get at garage
Oct 26, 2009 | 2008 Hyundai Accent
Fisher and Paykel Softline Refrigerator Globe Replacement
Remove the temp control housing so you can get at the bulb more easily. It unscrews counter-clockwise, it may just be stuck from prolonged seating. If necessary, unplug the fridge, break the bulb, and unscrew the socket with a pair of needle nose pliers on the outer edge of the socket. It may crush the socket, but that's ok, it should come out then. Good luck!
Sep 22, 2009 | Refrigerators
How to change globe on headlight ford focus 2005
brian_au no 1 solution is wrong.. globe is under a spring clip cover . remove cover, then unplug, then release retaining spring behind the globe. replacement is just process reversal
Sep 18, 2009 | 2005 Ford Focus
The light bulb needs replacing but..
It would have been really helpful if you could have provided the model number. You can always find it at the back of your freezer. Here are some links to videos which should be useful for you.
Jul 22, 2017 | Refrigerators
KitchenAid KSF26C4XYY 26.0 cu. ft. Side by Side Refrigerator with 4 Spill Shield Glass Shelves, Humidity-Controlled Crispers, External Ice/Water Dispenser and LED Theatre Lighting: Monochromatic Stainless Steel Logo
272 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
