Question about Maytag Dryers
My maytag neptune dryer shows upside down F 5 error code what do I do to get the dryer going again
SOURCE: Maytag neptune dryer won't start
This also happened to our dryer recently(our dryer is 6 yrs old). My husband replaced one of the capacitors along with a resistor(I think that's what it's called). If you don't know what you are doing then you can purchase on new board on ebay. My husband checked on there and they run about $90.
Posted on Sep 15, 2007
  • 4 Answers
SOURCE: Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Posted on Jan 10, 2008
SOURCE: maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Posted on Jun 12, 2008
  • 40 Answers
SOURCE: i have maytag neptune 5500-
When the 88 displays, put a heating pad over the display - it will be ready in just a few minutes. Sounds crazy, but it works every time.
Posted on Oct 03, 2009
SOURCE: maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Hope this helps
Posted on Feb 27, 2010
Dryer chirping along with the following: start button flashing, dry temp on high light lit, 56 on timer timed dry lit and dry time selector lit was on sensor dry when we left and turned off
Disconnect power or turn breaker off for about 5 minutes. This may reset the unit. Otherwise you have an eror showing and need to retrieve the error code. Google your make and model followed by error codes a d you should get a link to retrieve the codes.
Aug 08, 2016 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune Dryer won't start. Get an error
reset the dryer .disconnect the power cord by 30 -40seconds, and try again, if the problem persist with the error, read you owner manual in troubleshootign section. or dwonload the owner manual for identify the error problem, can be problem a temperature.
go to www.retrevo.com
God bless you
Jul 28, 2013 | Dryers
What is the code upside down F and a 5 ?
It is a TS error, I thought the same as you that it was aT5...lol...Anyways it is either the Thermester or the controller board. If you can afford it get a tech out there so they can diagnosis the problem ASAP. We didn't and ended up buying a new Thermester and our old one was just fine, it was the controller board that was dead since we put wet cloths on top of the dyer and the water leaked down on the board.....Wont be doin that again... :^)
Aug 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My Maytag Neptune dryer is showing an error code of 88. I have reset the circuit board, reset the dryer, but it wont turn on. Any help is appreciated.
Who ever posted put a heating pad on the display THANK YOU i put my wife's blow dryer on the back of the display and in 5 minutes its was working again THANKS AGAIN
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Does not turn on and run
CANT FIND CODE DRYER SHOWING UPSIDE DOWN F WITH #5
Jul 29, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
T5 error code
e5 code have replaced thermister
Jul 24, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
81 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
