Question about Canon BubbleJet i560 InkJet Printer
How to remove printer head on Canon i560
How do I remove printer head to respond to 5 blinking yellow error lights?
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
SOURCE: Cannot remove the print head from canon i560
try this - open cover on printer
on the right side of the cartridges is a grey arm - lift it up
remove all ink cartridges.
then remove print head.
Posted on Mar 08, 2009
e-ware
  • 776 Answers
SOURCE: Do I need a new print head?
1. Turn off printer
Posted on Sep 13, 2009
cene765
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
pineworks
  • 4041 Answers
SOURCE: Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
I have a Cannon i560 printer and the light on printer flashes five times orange then flashes green, what is the problem and how can I fix it.
1. Turn off printer
May 18, 2011 | Canon BubbleJet i560 InkJet Printer
My canon i560 printer won't print. I get an error message. The error message says to cancel print and press the resume button. This doesn't work. The yellow light is blinking 5 times then the green...
I got the same problem. I researched and found out it's the print head, you know the thing that moves side to side that releases the ink onto the paper. You either have to replace the print head( which costs around $50.00) or buy a print head cleaning kit because it might have dried ink in it. Hope this works for you( the kit didn't work for me, had to get a new print head)
Jan 21, 2011 | Canon BubbleJet i560 InkJet Printer
Jan 02, 2010 | Canon i9950 InkJet Printer
My canon i 560 does not respond at all. when i turn it on the light flashes 5 times orange and once green. and it repeats this
Generally speaking the Orange light flashes 5 times to indicate a print head error.
Did you recently remove and install the printhead? It may just need to be reseated. The printer may also need a service repair.
Don
Dec 12, 2009 | Canon BubbleJet i560 InkJet Printer
Oct 29, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
I have a Cannon i560 and I am getting 5 blinking yellow light the green and then it repeats. All indications is that I need a new print head. I want to be sure this is it before buying the print head.
5 blinking yellow or 7 blinking yellow in canon printers means you need to replace the ink cartridge or head with a new one. If you want to be sure, then take the print head and see if there is any burned area or damaged near the head and sometimes it is very small like a needle puncture. if there is, you need to buy a new one. if not, try to clean the head with 96% alcohol, let them dry before you try to put it back.
Sep 14, 2009 | Canon BubbleJet i560 InkJet Printer
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 printer
1. Turn off printer
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
37 people viewed this question
old marine
old marine
