Question about DeLonghi Kitchen Appliances - Others
Orange light on wont boil - DeLonghi Kitchen Appliances - Others
I am not sure how it work, and the orange lught indicating the hot water is constantly on wuth no sound indicating the water is being boil! is there a problem with that.
The light is either a standbye light, or liklly a fault, problem light, Turn off power at the unit, wait five minutes, and watch what the light does. It will blink, or change color, and the manual will tell you what the code means. It may be listed right on the unit, The light is a fault light, or a indicater light. Find out what it means.
Jul 18, 2015 | Heating & Cooling
Orange light on and it wont turn on
Is it an orange battery indicator? If it is, it means the AC adapter is charging the battery. Please charge the battery for 1 hour before you press the power button again.
Mar 02, 2014 | Dell Latitude E5500 Laptop
Vizio vp422 orange light stays on wont power up
I would double check the capacitors on the power supply board. Make sure you don't have any that are bulged at the tops. Secondly, when you try and turn it on, does the orange light flash at all??
Jan 20, 2013 | Vizio VP42-20A 42 in. Plasma TV
We've tried to start our Phillips Espresso Bar type HD5702/A, but can't seem to get the water to go into the coffee; Are there a step-by-step instructions on how to get it going (we got it from a friend...
There are merely 3 controls on the unit, two swithes on the right hand side and a turn knob on the left hand side. Press the upper switch - power should go on as indicated by a red light, the orange light of the lower switch indicating the unit is heating up. When the orange goes off, you can press the lower switch whitch starts the compressor to pump up the boiling water into the coffee. During coffee preparation the orange light may go on from time to time indicating the unit is reheating. Stop the pump when coffee is enough. When turning the knob on the left by 90degrees the unit will produce steam and feed it out through the metal nozzle at the left of the unit.
May 30, 2010 | Philips HD-5702
2000 firebird overheating coolant orange color. Was warming up in Driveway.
The coolant was boiling, am I correct in reading that? A muddy, dull orange color is bad. From what you've told me, it sounds like the coolant was never changed. What happened, then, is the coolant that was in there lost its anti-corrosion properties and started rusting out the coolant paths and radiator. The boiling over can be caused by one thing - the thermostat. What most likely happened is either the thermostat froze up or it is clogged with particles of rust and metal. My recommendation to you is to take your car to a radiator shop and have them look at it. If the damage is as bad as I think it is, don't be surprised if they tell you you will need a new radiator, thermostat, hoses and maybe a water pump.
Dec 09, 2009 | 2000 Pontiac Firebird
Lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Dell inspiron 1100 wont stay on
Normally the battery light will rapidly flash orange if the battery is defective. It will alternate between orange and green if it is too hot to charge. Or it will either flash orange or be a steady orange if the battery is low or completely discharged. Based on this and the fact that you cannot get it to stay on for more than 7 seconds, I would have to say that you need to recharge the battery by plugging the laptop into an AC outlet. After all, it can't run without the juice.
Apr 14, 2009 | Dell Inspiron 1100 Notebook
Electric coffee maker no longer boils the water
As you explain i understood that heating element is in defect. Even if you don't find replacement in part DO NOT THROW IT. only remove electrical parts and you use it in direct heat , with gas or fire. buon apetit.
Sep 26, 2008 | Bialetti Moka Easy 6-Cup Espresso Machine
Light or no print
1 the cartridge might be empty if its not then boil water and place in a shellow bowl (About a cm of boiling water) then place the cartridge in the hot water which should remove the dried ink and get your cartridge to release in properly.
May 07, 2008 | Dell Inkjet 720 Printer
Kitchen Appliances - Others Logo
32 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Gerry Harvey
Gerry Harvey
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
