E8 error comiong after washing in IFB washing machine 7kg direct drive
E8 error coming after washing in IFB washing machine 7kg direct drive
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
  • 41 Answers
SOURCE: error code 8
Could be water valve stuck open/ malfunction on coil. or possibly level control valve.
Posted on Sep 03, 2009
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
MNTECH
  • 1543 Answers
SOURCE: WHAT DOES ERROR CODE IE MEAN ON LG DIRECT DRIVE
IE = Inlet Error. Check for plugged screens where hoses screw onto machine (especially the cold side). Other possibilies are kinked hoses, valve shut off where hose goes to washer, or a bad inlet water valve (the part the hose screws onto), or even a bad control board or bad wire to water valve.
Posted on Nov 27, 2009
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
My ifb washing machine is showing dp error
Jul 05, 2014 | Washing Machines
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
How to reset ifb digital washing machine?
I have ifb digital 7kg machine.
When it reaches 0.13 and 0.19 it get pauses.
What to do.
May 13, 2012 | IFB Washing Machines
Heater wiring diagram 7kg front loader electrolux
IN MY IFB WASHING MACHINE SENATOR TWO WHITE CABLES CAME OUT I DONT KNOW WHEATHER TO JOIN THEM AND FIX TO HEATER
WHAT IS THIS WHITE CABLE. AT CONNECTING POINT THEIR INSULATION ALSO GOT BURNED THAT IS WHY THEY CAME OUT
Jun 01, 2011 | Electrolux Washing Machines
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
