Question about IFB Washing Machines
E8 displaying Error E8 are washing is complete
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Washing machine doesn't wash
E8 Means the temperature is too high. Replace the thermistor - temperature sensor, also known as NTC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: E8 error code
8E - OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Posted on Sep 15, 2010
  • 827 Answers
SOURCE: My daewoo washing keeps displaying
Did you look up your owners manual?
If it is not available, try getting one downloaded from online and reading it there...
Ck
Posted on Feb 13, 2011
Where is the distributary valve?
that is a very good question
i cant find a "distributary valve" for sale
lots of water inlet valves hot and cold single units
almost every dishwasher user manual and has code e8 mentioned and faulty distributary valve
why the fault
.If the distributary valve have worked for 150
seconds, and could not reach right
position during wash cycle,after the cycle is finished, the dishwasher will shut off all
loads, the alarm buzzer will ring for 30 seconds and the window will display "E8" at rate
of 1Hz in 30 seconds, and then display "E8" , drain water for 2 minutes meanwhile
May 12, 2016 | Dishwashers
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
Why is my machine not spinning
Well, it would help to know the make and model... on a Samsung the E8 code means the water hoses are connected to the wrong taps (i.e. the hot hose is hooked to the cold tap and vice-versa).
If it's not a Samsung, please provide more info.
Mar 08, 2015 | Washing Machines
Error E8 HP Laserjet MP1136
See this... http://h30434.www3.hp.com/t5/Other-Printing-Questions/m1132-hp-printer-gives-me-e8-error-code-is-it-expensive-too/td-p/907661
Jul 04, 2014 | HP Office Equipment & Supplies
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
My daewoo washing keeps displaying E8. what do I do to correct the error
Ck
Feb 13, 2011 | Daewoo Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
I have a Daewoo DWD FD1233. It's brand new & 12 minutes before end of cycle it comes up with E8 as an error. The machine wont spin after that. What can i do? Lots of wet washing.
Daewoo e8 - engine error! or Bad soldering.
Remove the control panel (the one in which many connections). Remove the rear rubber compound around contacts blue relay.
Resolder them. And it will be all ok!
Or - remove the entire back of the compound and look for where the bad soldering (cold soldering ). You can see it - blackened or exfoliated. Just solder all.
Jan 11, 2011 | Daewoo Washing Machines
May 10, 2009 | Washing Machines
E8 error code
May 02, 2009 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top IFB Washing Machines Experts
Raj Patel
ray gallant
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
