Question about Hardware & Accessories
I have TS-EE8 Timer and have not used it for few months and now the battery is not working anymore, can I replace it ?
Understand the instructions for TS EE8
Following link has product manual that might match your timer:
Use + button at top of manual to enlarge print.
http://waterheatertimer.org/pdf/Argos-7day-Electronic-Timer-Manual-TS-EE8.pdf
Please add a comment and say if this manual matches your timer...fixya will send me email... and I will answer.
Include where you get confused.
You set current time first... that's the time that shows on your wristwatch right now.
You set day of the week... same day it is right now.
You set hour and minute.
The timer allows you to set up to 8 programs... you can set just 1 program or 2 or 3 etc.
Each program must have ON time
You set program 1 ON
Each program must have OFF time.
You set program 1 OFF
Each program must have a day or days of operation
So you might select monday ON at 10:10 am and OFF at 3:36 pm.
And other program for Tuesday ON at 10:45 and OFF at 4:00 pm.
When programming is finished, you set mode to auto for programs to run on the schedule you set.
Gene
Water Heater Timers Save Money
Feb 28, 2015 | Hardware & Accessories
I have just got my Everflourish programmable timer out of the box having been stored for a few months and the screen is not turning on? Is there a battery that needs replacing or is there another reas
Reset timer?
And then reprogram.
Plug timer into wall for a few hours.
If timer does not have replaceable battery, then there is non-replaceable internal battery built into circuit board that must hold a charge for timer to function.
If this battery is left uncharged, it might drain and never recharge again.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
Dec 06, 2014 | Hardware & Accessories
Gardenmate tap timer
this kind of machine they need a traction battery
Nov 27, 2013 | Garden
Utilitech wall timer
Utilitec timers do not have replaceable batteries.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Older timer designs have batteries, while more modern timers have internal rechargeable battery that is integral with circuit board, and cannot be replaced. The battery holds memories in event of power outage, but current time must be reset if power is out for extended time.
If you have continual problems with failed timers, then have electrician friend run test on your power for spikes, shortages and surge that will cause timers and other non-hardened electronics to fail frequently. Also check for polarity and grounding issues. Also if you have motors, other electronics and/or fluorescent lights on same circuit, this can cause interference.
Also check load limitations, and load on timer to make sure you are not exceeding the timer rating. For example using timer to control motor when timer is rated for non-inductive incandescent loads.
Reset timer using reset button, and then re-program. Buy another timer at Lowes and return defect in new package for refund.
Buy Intermatic ST01C timer. This timer uses CR2 battery, and timer electronics operate separately from electric line. Rated for any load: motors, cfl bulbs, led, incandescent, etc.
http://waterheatertimer.org/ST01C-program.html
Add a comment
Jul 18, 2013 | Hardware & Accessories
Want to set timer on Provalue ts-EA1
Evidently there are several brand names selling TS-EA1 timer
1) Copy following links for possible TS-EA1 timer manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
http://waterheatertimer.org/pdf/TS-EA1-digital-timer-manual.pdf
2) This is a new series of 50 Hz timers made for worldwide 230Volt market.
Manual was written based on other similar timers, and how those timer buttons worked, although there is not another timer with 1:1 same buttons.
3) Add comment and say what you discover when trying to program your timer. Then possible manual can change accordingly.
Jan 06, 2013 | Sunbeam 6 Robinson Home Digital Timer
I have replaced the batteries on my Gardenmate Dual Outlet Tap timer, and it is still not working. The system is only 12 months old, and I am unable to solve it. Can you please help me.
I reckon they're useless. New batteries still aren't powerful enough to drive the whirring gears of the timer inside (they only take AAA batteries).
I have the same problem as you, which has happenede on both timers I've bough...they usually give out after a month or so and nothing gets them going again,
Sadly a dreadful product, poor design and waste of money. Shame really as it could be so good to really "set and forget"
Feb 20, 2011 | Garden
My laser 73 heater has an error of ee8
Hello
An ee8 message refers to the combustion Blower motor
Unplug unit
Take off front cover
There is a rubber hose from blower case to the base of the unit
Take it off carefuly
Use your finger or a Pencil to try to move the intake fan
Resemble unit
If this doesn't work you may have to replace Blower motor or just clean it up.
If you can't figure it out gimmie a call Total Toyo (907) 488-9179
Dec 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Pentex model, optio E60, get a message'"lens error:0x01110000"
after replaced with 2 fully charged battery, and pressed a few times on/off, it worked. and problem solved.
Feb 14, 2009 | Pentax Cameras
Hardware & Accessories Logo
231 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
