Question about Intermatic Hardware & Accessories
Tsee8 timer I have an old timer and the battery is not working anymore, can I change it and how pls ?
How do u know when to change the batteries in a orbit 2 outlet hose faucet timer
one might think when it doesn't work anymore . or at least once a year in the spring
Jun 29, 2015 | Orbit Hardware & Accessories
Gardenmate tap timer
this kind of machine they need a traction battery
Nov 27, 2013 | Garden
Timer wont turn on
Add a comment and include timer brand and model, or describe timer in detail.
Is timer plugged into outlet? Or harwired?
Does outlet have power?
Is circuit breaker ON?
Is this new timer, or old timer that stopped working?
Reset timer.
Change battery?
What load is being controlled by timer?
Mar 29, 2013 | Hardware & Accessories
Valves don't operate
Unknown if this is new installation, or old installation that stopped working.
Clean waterway inside timer with white vinegar?
Change batteries?
Reset and reprogram timer
Most timers have 1 year limited warranty against defects in workmanship.
Expected lifespan for battery-operated water timer can be 6 months to 5 years.
There are no replacement parts.
Complicated digital timers can stop working for variety of reasons.
Buy another timer.
Copy following link to download manuals for several brands water timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Oct 06, 2012 | Orbit 57882 9 Station Super Dial...
Irrigation timer
Which timer?
Have you reset the timer?
Is this new or used, or old, or worked before, is the timer battery-operated?
Have you changed battery?
Add a comment.
Copy following links to help identify timer.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Sep 08, 2012 | Hardware & Accessories
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aug 05, 2011 | Woods InWall 7 Day Digital Programmable...
I have replaced the batteries on my Gardenmate Dual Outlet Tap timer, and it is still not working. The system is only 12 months old, and I am unable to solve it. Can you please help me.
I reckon they're useless. New batteries still aren't powerful enough to drive the whirring gears of the timer inside (they only take AAA batteries).
I have the same problem as you, which has happenede on both timers I've bough...they usually give out after a month or so and nothing gets them going again,
Sadly a dreadful product, poor design and waste of money. Shame really as it could be so good to really "set and forget"
Feb 20, 2011 | Garden
I found out the intermatic did not work as usual, just change new battery, i try to program the schedule, but it did not work.
If you have a battery operated timer, it is probably the Intermatic ST01C or EJ500.
http://waterheatertimer.org/Programmable.html
The link above will help you identify your timer.
As a general rule, if a new battery does not revive the Intermatic timer, then timer needs to be replaced. Make sure you have electricity. And be sure to mark your wires before removing timer. Mark the black wire that connected to timer-black wire. It's the hot wire from breaker box.
You can replace with same model and brand so your wiring is EZ.
The ST01C and EJ500 are 7-day timers with up to 40 programs per week. They each connect with 2 wires. Black and Blue with red wire capped off. Just mark your wires before you disconnect old timer. And then reconnect new timer wires just as old timer was connected. The red wire is capped off.
The Aube T1032 is also a 7-day timer with 7 programs per week. This timer connects a bit differently. It connects with 3 wires. You put the black where old timer-black wire connected. And then you connect the red and blue together and connect them where the old timer-blue wire connected.
Other timers require wiring that is bit different, but the page link above shows the wiring ... and you can re-post another question any time >>> or respond to this answer.
Keep us posted.
Oct 22, 2010 | Hardware & Accessories
MY CALCULATOR IS NOT WORKING ANYMORE BUT IF I PUT IT THROUGH TH LIGHT IT WORKS,,BUT I CANT DO IT ANYMORE,PLS HELP OR MAYBE ILL GO BUY NEW ONE..LOL
Hi:
if puttin it to the light makes it work than what you got is some dead batteries you need to replace . Check the back cover and see what batteries your calculator need to be replace it with; than go to the watch repair dept in walmart or meijers buy two batteries and have them take off the back cover and remove the old batteries and replace them with new put your back cover on and your calculator will work as good as new.
Oct 07, 2009 | Office Equipment & Supplies
Change Battery Message
Clean the battery contachs- use a pencil eraser to get at those in the base of the chamber. Then try. Some timer the cap that closes the battery chamber is no longer making tight contact- keep it pressed in with a finger when taking shots. If all this is to no avail get onto Canon Technical Support.
Nov 14, 2006 | Canon PowerShot S500 IXUS 500 Digital...
Hardware & Accessories Logo
89 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
