Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
My Sony KDF55WF655 Grand Wega will not turn on. No power at all, and there are no LED's of any color. It's as if it wasn't plugged in. This happened after a local power outage. The Sony wasn't turned on when the power went out. I know it's not a lamp issue, since I changed the lamp out about 4 mos. ago. I would guess that an internal fuse needs to be replaced. Would that be the "thermal fuse" that I've read about here? Help a bro out... Thanks all. Jan
Did you find a solution for this problem? The same thing happened to me.
Posted on Jul 28, 2010
How do you fix a lamp ballast board on 50 inch sony grand wega
The ballast board will need replacement you can get the sony Lamp ballast 146892712 used in the KDF55WF655 models, from www.tvrepairworld.com listed under the sony DLP circuit board cxategory
Oct 28, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand Wega KF-WE50, no LED lights, wont turn on, fuse is OK ?
Try plugging into another known good wall outlet. if still not standby light then the power board needs replaced.
Mar 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony grand wega KDF55WF655 6 red blinks
you can try these steps if this doesn't work I suggest replacing IC8002 on the power supply
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony KDF55WF655 Grand Wega will not turn on. No power at all, and there are no LED's of any color. It's as if it wasn't plugged in. This happened after a local power outage. The Sony wasn't turned on...
Even with the set turned off, there is always a circuit that is active. There is what is called a "standby transformer" that supplies power for this. It is quite possible that the internal fuse of this transformer has opened up. This is a common failure. There should also be an external fuse that may be open as well. Check for any "glass tube" type of fuse close to where the AC cord attaches to the set (inside and with the set unplugged). Try changing that fuse first. If that does not resolve the problem, the standby transformer is the next likely suspect.
Dan
Jun 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF55WF655 TV ready green light blinks 30 times
Could be a bad lamp again. If this TV uses the XL2200 lamp, they are known for this intermittent behavior. If its not the lamp, a tech can access the self-diagnosis screen to see what's causing this failure.
michtech
Feb 18, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony grand wega model kdf60wf655 cycles on and off.
My kdf55wf655 did this for about a week until I put in a new Lamp. Working fine since then. Got it through Amazon from www.vanns.com.
Dec 15, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green standby/power light bilnks and pic goes out
you have defective power supply! at the hot side section!
Oct 08, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
